Old 09-11-2011, 08:01 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Couple of Oil cooler/lines questions
Hey - after working all weekend on figuring out a way to mount and install the larger oil cooler to the firewall on my Rv-7A, I can see the light at the end of the tunnel.
I decided to switch to the larger cooler now, after speaking with the folks at Aerosportpower. For their IO-375, they recommended installing an oil cooler that was larger than the standard one Vans sells.
FYI - I ordered the mounting kit Vans sells to firewall mount the larger oil cooler in the RV-10. I could not figure out a way to make it fit and for the scat tubing to clear the motor mount.... so I fabricated one from scratch. As you can see, I don't think it turned out too bad. I still have to trim it a bit to clear the skybolt fasteners for the cowling, other than that it's pretty much finished.
Anyway.... on to my questions.
1) I have to order new oil hoses. I understand best practices is to plumb the output from oil pump the the low side of the cooler... which of the oil line outputs on the engine the high pressure side of the pump?
2) How can I protect my motor mount from the scat tube rubbing? I'm sure that there is a elegant solution, but I'm drawing a blank.... I haven't seen any Adel style clamps that go up to 4"... Any suggestions?
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 09-12-2011, 05:28 AM
Smile Jason-
Plumb the pressure outlet to the inboard port, and the return to the outboard side. Straight hose ends at the cooler, and whatever it takes (90*) at the accessory case.
The mount tube/SCAT tube can be protected with a piece of wire loom, or better yet, firesleeve tape. Rugged, fairly thick, and heat resistant. You can also fab a clamp/bracket assembly to move the SCAT tube away from the mount tube slightly, and secure it at the same time.
Tom
Ridgeland, SC
Last edited by TS Flightlines : 09-12-2011 at 05:31 AM. Reason: added thought/spelling
Old 09-12-2011, 05:55 AM
mburch's Avatar
mburch mburch is offline
It's common to use a strip of stainless sheet here to make your own clamp for scat hose - doesn't have to be cushioned. Van's sells a pre-cut strip for this (P/N SS304-26GAX1/2X9). I personally would use a clamp like this plus as much RTV as necessary to keep the tube from touching the motor mount directly.
good luck,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 09-12-2011, 06:55 AM
DanH's Avatar
DanH DanH is offline
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-12-2011, 11:01 AM
Rick6a's Avatar
Rick6a Rick6a is offline
. I haven't seen any Adel style clamps that go up to 4"... Any suggestions?....
I did not like nor was I inclined to use the S.S. strips that came with the kit so I ordered a couple of cushioned clamps. As you can see, 4" Adel clamps do exist. I cannot immediately recall the vendor but I'm sure someone reading this can provide you with a link.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-12-2011, 11:35 AM
UnPossible's Avatar
I just checked and McMaster Carr has 4" clamp for ~$3.... that should totally take care of my rubbing issue.
Jason Tremble
Paid for 2020
Old 09-12-2011, 12:03 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default For your arrangement a gob of RTV...
For your arrangement a gob of RTV would work fine.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
