Old 09-09-2011, 08:32 PM
Junglepilot's Avatar
Junglepilot Junglepilot is offline
Default Fuel pump outlet fitting proper tightening question
Not much experience with Lycoming mech fuel pumps.
That said, I have the 90? fitting with the tap for fuel pressure line and wondering about the tightening sequence for the fitting into fuel pump.
The jam nut that presses the o-ring I understand, but how tight should the actual fitting be.
Right now snug + 1/4 turn leaves the 3/8 male pointing to accessory case which won't allow me to attach fuel line to carb. However concerned that another 3/4 turn may crack FP neck.
Is the purpose of the jam nut to allow for getting the fitting in the right position then allow the jam nut pressing the washer & o-ring to seal the joint without leaking? I added some fuel tank sealant to the threads also.
Sandy Toomer
Commercial, Instrument, A&P
EAA: 1023750
Based Lanett, AL (7A3)
Auburn, AL
WAR EAGLE!
Old 09-09-2011, 11:05 PM
terrye terrye is offline
Default Jam Nut
The threads are parallel threads like a bolt, so I don't think the fitting bottoms against anything, therefore the fitting does not have a tightening torque. The jam nut locks the fitting in place once it is clocked (except for straight fittings) and also acts as a seal for the o-ring. I think the tightening torque of the jam nut would be the same as a hose fitting swivel, Aeroquip has a chart and I think also on Van's site.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 09-10-2011, 05:21 AM
Default Good info
OK, I didn't know that about the parallel threads. It didn't appear to be a pipe thread (tapered).
What I did was turn it in several turns with tank sealant on threads, position it to desired angle, then tightened up the jam nut/o-ring combo as you suggested using good German torque for now (Gutntight). Didn't have the chart, but I'll look on Aeroquip site for that.
Thanks!
Sandy Toomer
EAA: 1023750
Auburn, AL
WAR EAGLE!
Old 09-10-2011, 05:25 AM
Pat Stewart Pat Stewart is offline
Thanks!
Not sure about tank sealent, You should position the fitting to align with the fuel hose and tighten the jam nut.
Old 09-10-2011, 10:39 AM
jrs14855 jrs14855 is offline
Post pump fitting
This is standard Pitts setup. No sealant on threads. The fitting MAY bottom out. If it does I prefer to back it out less than one turn. I have never seen a specified torque for a jam nut with an o ring. It would be pretty hard to get a meaningful torque reading. This same setup is used on many low wing Pipers. Pitts and Piper do not normally pick up fuel pressure at this point.
