Old 09-07-2011, 07:42 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Tip: More Room - Empennage Access Cover
I have short and stubby hands, not the kind that fit into the opening of the empennage access hole very easily. On the F1 Rockets, the hole is even smaller due to the location of the aft most ribs. If I was ever going to get my hand inside there to connect the rudder horns to the torque tube, I needed to create more space.
I don't remember where I got this idea but I borrowed it from another builder. In all likelihood, it came from Tom Martin, but I can't swear by it. I hope this is something that you might be able to use on your empennage to give you at least another 1/2" or more of access space. Enjoy!
I made the parts shown above. I cut the access ring to cover slightly less than the bottom half of the hole. On top of the cover, I made a small tab. At the top of the access opening, I made a clip for the tab to slide in behind.
Here are the part clecoed in place. The tab at the top is slipped into place to check the clearance. Please note that on my airframe, the holes for the full access ring were already drilled so I had to make parts to fill in behind the part so I could insert a rivet into the pre-drilled holes. Youmay not need to do this if your parts are not already drilled.
Here's a picture of the backside.
Here's the finished product. The final result is more space for your hand, less screws, and less weight.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-07-2011, 08:12 PM
logansc's Avatar
logansc logansc is offline
Randy: That's another great tip from you. Only a child could reach into the aft inspection plate on mine. Wish I had thought of that myself. Very clever and neatly done.
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
