Old 09-06-2011, 10:09 AM
rph142's Avatar
rph142 rph142 is offline
Default Cheaper Panel Options!?!
I'm starting to have serious concerns that my refinery will be shutting down sometime next year, which would of course put me out of a job. Meanwhile, I have my RV-3B all paid for and basically finished minus just one component - the $8500 Skyview EFIS, Transponder, GPS combo. I REALLY want to get this thing in the air later this year or early next, but dont want to empty my wallet incase work shuts down next year. Im looking for any ideas for how I can finish this off with what i have for as cheap as possible.
What I have:
two panels - one blank and and one that loos like this:
So I have the Dynon EMS wiring package installed, 2 1/4" airspeed, mgl radio, and some switches on the side.
Any suggestions?
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 09-06-2011, 10:22 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Give Dynon a call, see if they can come up with a lower cost option, that will work for you.
Also, the MGL IEFIS might be an option to look at.
http://www.vansairforce.com/communit...ad.php?t=74245
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-06-2011, 10:25 AM
aarvig's Avatar
aarvig aarvig is offline
Default Look in the FAR'S...
to see what is required for day VFR (or night if you are flying at night too). Install that...guaranteed to be significantly more affordable than what you are planning on installing now. What do you want or what do you NEED?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 09-06-2011, 11:35 AM
dsmith1055's Avatar
dsmith1055 dsmith1055 is offline
Default Cheaper panel options
Check with Stein for options that fit your budget.
Dwight Smith CFI
Flight Advisor - Tech Counselor
Old 09-06-2011, 12:00 PM
Brantel's Avatar
Brantel Brantel is offline
A D180 ~ $3600 new, less if used
A used KT76A xponder ~$600
A used X96 GPS $600
It should all fit in that big hole you got there. Just make a subpanel to mount it in that fits that hole.
Upgrade to the Skyview later if the job holds out..
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-06-2011, 12:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Since you already have the wiring installed, the easiest option might be a used Dynon D-180.
Since the harness to the engine is common, a later upgrade to the Skyview would not be to difficult.
Sorry, sold mine a couple of weeks ago...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-06-2011, 12:25 PM
There are frequently used steam gauges available in the classifieds. With those and a cheap handheld all you'll need is a transponder and you're flying.
Dave
Old 09-06-2011, 12:32 PM
rv7charlie rv7charlie is offline
And unless you live under Class B or C airspace, you could probably do without the transponder. The -4 I currently fly didn't have one when I bought it about 8 years ago, & still doesn't.
Grand Rapids has some air data options for their EIS; it might be worth a look to cover all your bases in a VFR-only plane.
Charlie
Old 09-06-2011, 01:04 PM
chaskuss chaskuss is offline
Default Temporary or Permanent?
Rob,
Will the "cheaper" option be a temporary solution? Or will it be permanent? For a temporary fix, you could get a Rocky Mountain MicroEncoder [$350 to $500 used, depending on if it comes with the magnetometer and condition]. A hand-held GPS could also be used.
The MicroEncoder contains an encoder, airspeed indicator, VSI and altimeter. It also has an OAT gauge. For more info, go to the web site and click on the links for the MicroEncoder [aka uEncoder] See
http://www.rkymtn.com/
This is just one option.
Charlie
PS The MicroEncoder could be left in once you get your "permanent" solution. It would provide a nice back up of all your primary instruments.
Old 09-06-2011, 01:08 PM
bkthomps bkthomps is offline
Charlie
in today's airspace i'd consider this a personal minimum, i want people to see me and have every chance to avoid me
