10-11-2011, 07:08 AM
Fuel lube, EZ turn
Originally Posted by prkaye
So I spent some time yesterday tracking this down.
With the engine off, I started the boost pump and fairly quickly got a whiff of gas. So I started checking fittings.
I found a leak through the pipe-thread on the elbow fitting that penetrates the firewall into the gascolator. Gas seeped out through the tapered pipe thread when the fuel pump was on (this is the first fitting downstream of the fuel pump, so probably a fair bit of pressure there). I could actually tell that the carpet underneath that fitting had been getting gas on it.
I replaced the elbow and put Loctite 567 Thread Sealant on the threads this time (i had previously just used fuel lube). Waiting a couple of days for the sealant to cure and then I'll pressurize the system and check again.
I HATE TAPERED PIPE THREADS!!!
It's been my experience in the past, that every time I used Fuelube/EZ turn for a thread sealant, that fitting eventually leaked!!!!! I now use anything that says "thread sealant" on the tube for my pipe threads. I think I use loctite 561 with good success.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
10-11-2011, 07:17 AM
Ok, yes, this has been extensively discussed earlier in this thread and in many others. As I wrote in my final post on this thread a few weeks ago, I solved the leaky pipe thread problem using Loctite 567.
Today's post is an update and a question - I am now getting only whiffs (only noticeable with auto gas), and I only seem to get the whiffs in a climb (no smell in cruise at any power setting). I suspect that this suggests a venting issue - am looking for validation of this suspicion.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-11-2011, 07:45 AM
Phil
It is possible, as you suggest, that you are getting vent fumes into the cockpit at climb angles. Is it the same at full fuel vs lower fuel levels?
Also what about directing the vent outlets and away from the cockpit area to test that theory. If you do this you should experiment the technique with one tank first to make sure that the tank is still properly venting.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
10-11-2011, 04:06 PM
Maybe ??
See post #31
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
10-11-2011, 04:55 PM
Symptoms are exactly the same as my recent bout with a fuel leak. Fuel smell in the cockpit at low airspeeds and low power settings. I was told that the vent tube is the likely cause...
Turned out to be a fuel leak at the wing root, tank end rib. Wasn't leaking enough to make fuel stains, but at low power settings and low airspeeds the fuel vapor would find it's way into the cockpit. I did finally find some fuel stain near the vent tube fitting on the tank itself reinforcing the false belief that the vent system is at fault. Pressurizing the tank with over half a tank of fuel revealed a leak coming from behind the tank support bracket. I don't know what the tank is pressurized to in flight by the vent system, but it didn't take much for the tank to start leaking on the ground (it wouldn't leak otherwise); really just closing off all the fittings and squeezing the tank by hand was sufficient. Talcum powder is a great idea and wish i'd thought of it when I was trying to find the leak.
I removed and repaired the tank last week. Flew it for the first time since the repair today. No fuel smell.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
10-12-2011, 07:18 AM
Hmmm... what I was trying to explain (unclearly it seems) in my recent update post yesterday is that my symptoms are DIFFERENT now after my fix of the one seeping fitting. Now the smell is much weaker, and it's not low power settings that triggers it now - these new wiffs now seem to occur at low airspeeds. I get them in a climb (at high power), and a little bit when taxiing or idling (low power). In cruise I don't get the whiffs.
Suspecting either venting, or a subtle leak on the inboard end of the fuel tank(s) as in the case of the previous post (although I had the fairings off recently and found no obvious leaks there). In cruise, it seems whatever it is gets blown away unnoticed. The hunt continues. At least now it's only occasional mild whiffs.
Phil
RV9A (SB)
Ottawa, Canada
