Old 09-04-2011, 04:12 PM
N130PM's Avatar
N130PM N130PM is offline
Default Repairmans Cert
I somehow put this over in the RV-12 section so I'll post it here just in case.
The discussion on this board as to who can maintain an experimental results in anyone can do anything since part 43 excludes experimentals. So why do I need the repairmans cert? My FSDO had no idea what I was talking about and I listened to him google it for ten minutes. What if I don't have one, I already passed the test as the builder.
Old 09-04-2011, 04:28 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
The repairman's certificate allows you to sign off your own condition inspections.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 09-04-2011, 04:29 PM
Jamie's Avatar
Jamie Jamie is offline
The Repairman's Certificate is a bit of a misnomer. It's really an authorization to sign off the annual condition inspection for that one particular airplane. That's the only authority the repairman's certificate gives you over anyone else.
Old 09-04-2011, 04:30 PM
Mel's Avatar
Mel Mel is offline
The repairman certificate allows you to perform the condition inspection required by your operating limitations.
ref; 65.103 and 65.104 for amateur-builts and 65.107 for E-LSA.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-05-2011, 01:07 AM
N130PM's Avatar
Thanks for the info, thats what I was looking for.
