Old 09-04-2011, 07:20 AM
Captain Avgas Captain Avgas is offline
Default Strobe wiring connector
I would like to insert connectors at the wing roots for the strobe wiring running to each wing (to facilitate later wing removal).
This would mean running the strobe shielding through a pin in the connector.
Is it possible that this set-up could result in "noise" in my radio (or other problems) due to the active strobe wires being unshielded in the vicinity of the connector.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 09-04-2011, 07:36 AM
Mel's Avatar
Mel Mel is offline
The small "break" in shielding should not cause a problem unless it's very close to wiring that it could interfere with.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-04-2011, 08:42 AM
Brantel's Avatar
Brantel Brantel is offline
I would ditch that idea. It is super easy to just disconnect the wires at the strobes and pull the whole cable out for wing removal if you ever need to. Pulling the wings in the future means something major has happened so taking 5 minutes to pull out the cable would be insignificant.
Extra connections create more opportunities for failure...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-04-2011, 08:56 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Terminal Board
I placed terminal boards on the inside of the fuselage side skins and use them to connect strobes (carry the shields thru the TBs), lights, pitot heat, roll servo... basically everything except antenna leads, because I didn't want to introduce .2-.5 db of loss on those. Those can easily thread thru conduit.
Three-fold benefits: 1) Cheap, 2) In the unlikely event of wing removal, it wouldn't be difficult 3) I can build and wire everything at home for plug -n- play after the airport move.
Terminal boards also allow for a port for troubleshooting. The downside might be that there is a risk to exposure to foreign objects. However, strategic placement or covering reduces that risk. Connectors are also a good choice. I have those in the wingtips, as they are much more likely to require removal and re-installation frequently.
You could use screws or proseal to attach them.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 09-04-2011, 09:05 AM
flion's Avatar
flion flion is offline
Use CPC connectors for all your wing wiring at the root. I've seen more than one case of having to remove a wing; if you don't do it then Murphy's Law will decree that you should have. The CPCs are the neatest and easiest way to manage this task; they insure you have a positive connection and you can more easily make additions and changes.
EAA Technical Counselor #5357
Old 09-04-2011, 04:05 PM
sf3543 sf3543 is offline
Default Leave some slack
I'd just leave a little slack inthe fuselage in the event that the wing ever had to come off. (which will likely not happen anyway) then you could cut the wire and put on a connector after reinstalling the wing. The connector likely won't fit through the hole you make for the wire anyway.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 09-04-2011, 04:27 PM
aerhed aerhed is offline
That's how I like it too. One CPC for each wing carries everything (except antennae). Makes a nice termination when you're wiring out the fuselage and gives a quick troubleshooting point also. Big planes do it, you can too.
Actual repeat offender.
Old 09-04-2011, 08:16 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Cannon plugs
Here's what I'm using at both the tip and the fuselage connection. I'm using all Aveo LED's, position, strobes, landing and taxi. The faston terminals are the airframe grounds for the lights. These are 9 pin Mil spec locking connectors.
The wing/fuselage connection provides little room. A connector will be mounted to the fuselage in a 90 degree mount like that in the photo. This will provide a simple, quick connector.
I should point out that that one wing has a heated pitot tube and each wing has an Advanced Flight System temp probe. The wiring is included in these connectors.
[IMG][/IMG]
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 09-04-2011, 08:52 PM
Wayne Gillispie Wayne Gillispie is offline
I am leaving some extra and butt splicing at wing root. No conduit in my wings to allow wires to chafe. The only ant conn is mb and a loss is not important. I have molex or amp conn at pitot/strobe/nav and dsub for roll ap servo/roll trim...so plenty of places to troubleshoot.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-05-2011, 06:11 PM
I was going to install connectors at the wing route but decided not to. It took me about 1 minute to pull the wiring through the wings. (I have a piece of string on all conduits) and realized that should the wings need to come off sometime, I'll detach at the wing tip lights and pull. I left a generous service loop so that there's no problem reinstalling connectors for the light later.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
