Old 09-04-2011, 07:11 AM
s24789 s24789 is offline
Default Inspection paperwork question
I am about to send in our request for airworthiness certification paperwork. We have reserved an N number for the airplane. Should I use that that number on e request paperwork or leave blank. Trying reduce paperwork issues. Thanks in advance for help.
Old 09-04-2011, 07:25 AM
Wayne Gillispie Wayne Gillispie is offline
Yes, use your reserved number. I just sent mine off Tue. (8050-1; 8050-2; 8050-88 and $5.00) They don't make it simple do they. If we make a mistake, we will go into the 3-5 week pile on the return trip to OK.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-04-2011, 07:33 AM
Mel's Avatar
Mel Mel is offline
Not quite sure I understand what you're asking here. Don't send any paperwork in for airworthiness certification until the aircraft is properly registered.
You WILL send in a copy of your "reserved" registration number with your registration request asking that that number be applied to that aircraft.
After you receive your registration, you will then send in your airworthiness certification request.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-04-2011, 08:04 AM
I think he really meant reg paperwork.
I res my # online. They said to write the res # on the three forms mentioned above. Then when we get the 8050-3 back from OK, we have that available along with AW cert req and all other paperwork for DAR or FAA insp.
Old 09-04-2011, 08:16 AM
Mel I thought both requests went in at the same time. Is this not true ? Please advise.
Phelps
Just put the wings on yesterday for the first time and drilled rear spar,
. I can now say it looks like an airplane.
Old 09-04-2011, 09:51 AM
Mel's Avatar
Mel Mel is offline
Default Nope!
The airworthiness certification cannot be started until the aircraft is properly registered, as all airworthiness paperwork is based on the registration information. i.e. The make, model and serial number on the 8130-6 must exactly match the registration.
The registration request goes to Oklahoma City. The airworthiness request goes to your inspector.
Old 09-04-2011, 01:47 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Phelps
Check the EAA website under the homebuilders section. The exact set of steps to follow is there.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-04-2011, 06:46 PM
Figured it out. The n number goes with the registration paperwork to the FAA. After weight and balance and program letter then the application for airworthiness cert. Is files with FAA.
Thanks for the help
Phelps
