Old 09-03-2011, 02:10 PM
chepburn's Avatar
chepburn chepburn is offline
Default What covers the mechanical Tach pick up?
Hi All,
I am using a sensor on my magneto for RPM. The mechanical pick up on the accessory case is not used. (IO360-A1B) What should cover that? Should I cap it with a fitting? If so, what kind?
Thanks for your help in advance,
Chris
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 09-03-2011, 02:23 PM
Wayne Gillispie Wayne Gillispie is offline
ACS# 10-06754
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-03-2011, 02:37 PM
roee roee is offline
Good recommendation by Wayne. Note that there are other tach covers on the market, but that one is the only one I've seen that has provisions for safety wire. Without that, tach covers have a tendency to work themselves loose and disappear in flight, so I've heard.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 09-03-2011, 03:37 PM
Walt's Avatar
Walt Walt is offline
I'm pretty sure Avery tools has them too (at least that's where I got mine a few years ago).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
