Old 09-02-2011, 09:54 PM
flion's Avatar
flion flion is offline
Default VAF Name Badges
A short while back, the subject of badges to help us to recognize each other at fly-ins and such was raised and I offered to upload a template I created, pending permission from Doug to use his logo. Well, he gave it, so let's move forward. Below is a picture of what I put together; it's intended to be used in a lanyard-style badge holder.
I've made a Word template which you can get at http://www.flion.com/media/VAF Badge Template.dotx. It's rough and probably needs some kinks worked out. You should be able to right click on your avatar, select copy image, and then past the image right over the logo placeholder in the template. Things may go awry with pictures, though, as I found the picture I used did not print well and the sizing may prove to be an issue. However, that part of the badge can always be ignored; it's a back-side image anyway. There may also be some font size issues with longer names or VAF IDs. But I'm sure we can work them out and the price is free. I'm also not sure how this will work on Mac Word or older versions. And, finally, you may need a different size format. I used a common lanyard holder but there are others or you may want to use a pin-on holder that's a different size. If I get enough requests for different sizes I may make a series of templates and a web page for downloads. Like I said, I'm just getting started with this. So, try it out, give me some feedback, and maybe we'll start seeing these (and each other) at events.
EAA Technical Counselor #5357
Old 09-02-2011, 11:26 PM
RV6_flyer's Avatar
Patrick:
I am one of the many that is not using Microsoft Office 2007 or 2010. Can you save your work in Word 2003 so that those of us that refuse to upgrade every time something new comes out?
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-03-2011, 12:41 AM
bruceh's Avatar
bruceh bruceh is offline
The template works fine with OpenOffice (free download).
Bruce Hill
2020 VAF donator
Old 09-03-2011, 07:54 AM
flion's Avatar
Originally Posted by RV6_flyer View Post
Patrick:
But, it's been five years since 2007 released! Thanks, Bruce, for the OpenOffice tip, but I suspect that he (and others) will not want to install that anymore than they want to upgrade - and I can't say I blame them. I'll add an early-version version to the list.t
Edit: Ok, backwards compatibility bites. I can save the template as a W97-2003 template but it strips the forms (of course). However, Word 2010 apparently does not offer the ability to add the old-style template tools back into the document. In other words, I need to have an old version of Word to create an old-style template. I can offer the raw template to someone with an old version who is willing to add the forms controls; it looks like the layout is unchanged. If you can help, email me, webmaster@flion.com, and I'll send you the template file.
Old 09-03-2011, 08:27 AM
Snowflake's Avatar
For what it's worth, OpenOffice can read and write Office 2003 formats (and earlier) and the modern formats as well. If you're using Word 2003 and occasionally get frustrated by someone sending you a newer version file, you'd be better off ditching Word entirely and going with OpenOffice. For 99.99% of users, the feature set is identical, and the price can't be beat.
Rob Prior
Old 09-03-2011, 03:33 PM
Walt's Avatar
Walt Walt is offline
I think everyone should have a T-shirt with their name on it
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-03-2011, 03:54 PM
Greenley's Avatar
Greenley Greenley is offline
Default Reading new word files
While it won't help with this template .dotx files, there is a download from microsoft that will allow you read read most 2007 or 2010 files in 2003.
http://office.microsoft.com/en-us/wo...010044473.aspx
Bill Greenley
RV-10 standard wing stage
Old 09-03-2011, 04:52 PM
tkatc's Avatar
tkatc tkatc is offline
Hey Walt,
I'll buy one of those T-shirts if you have a batch.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 09-03-2011, 05:10 PM
Walt's Avatar
Originally Posted by tkatc View Post
Hey Walt,
Thanks for the support Tony, the wife had a few made for me to bum around the airport in so I don't have any extras, but I'll send you one from the next batch
Old 09-03-2011, 05:51 PM
John Clark's Avatar
John Clark John Clark is offline
I Found the art for the back of my 'badge'...
John Clark ATP, CFI
FAAST Team Representative
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
