I would get a 90° filter adapter that puts the filter at the 11 o'clock position (viewed from rear). You will also need an extension to get the filter to clear the engine mount (I think 1.4"). B&C and ECi both make these adapters and extensions.
I have an airwolf remote filter on my 6A (O-320), and the 90° adapter on a One Design (IO-360-B) - oil changes are easier with the adapter, and the installation is easier and a couple hundred $$ cheaper.
Pete
Reason: typo
