Old 09-01-2011, 05:53 PM
kbehrent's Avatar
kbehrent kbehrent is offline
Default New Drift HD Action Camera
I've been researching HD cameras that I could install in the cockpit to record my first flight along with documenting some of the phase I test flights. I also want to capture the audio from my intercom and radios. I want a simple plug-n-play solution without voiding my warranty by hacking into the camera and replacing the built-in mic.
The Drift cameras are one of the few that have both a built-in mic along with an external mic jack. Not sure how good the audio is when plugged into a headphone jack or directly wired into the audio panel. I have the PSE 9000EX audio panel, which is a 4-place audio system, so I could easily dedicate one jack for the camera if I don't want to use the co-pilot one.
Since I'm ready to fly, I decided I better make a decision so I started looking again and noticed that Drift has a new HD camera, Drift HD Action. Below is a list of differences I found when comparing new HD camera to the HD170.
Differences between new Drift HD compared to HD170:
Recording Angles: 170 deg in 1080 mode instead of 127deg
Replaceable lenses
Improved 2.5mm external mic jack easier audio recording
Remote Range: 5m range instead of 10ft
Photo resolution: 9mp vs 5mp
Dimensions: 30mm shorter in length & better aerodynamics than HD170
Weight: Lighter (119.1g vs 138.9g)
Supposedly smarter, more programmable than the HD170
ED: This camera won't be available in stores until early October
I would be interested in hearing from anybody that has used this new camera or the HD170 and connected the external mic jack into the aircraft headphone jack or audio panel.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Last edited by kbehrent : 09-01-2011 at 06:12 PM. Reason: Added camera availability
Old 09-01-2011, 06:36 PM
RetiredRacer RetiredRacer is offline
We got the HD170 Drift in April for our first flight. We found the mount has to be well braced to stop any vibration. But are now more than happy with it.
The one we got has the external mic jack, and has the 170 deg lens rotation.
Someone else on here advised a flat mic in the headset. I tried that and it is excellent.
Old 09-01-2011, 11:23 PM
kbehrent's Avatar
Where/how did you mount it inside?
Kevin Behrent
www.teenflight.org
EAA Chapter #326
Puget Sound, WA
RV-9A
Old 09-03-2011, 08:27 PM
We have two mounts inside. The drift comes with several clip in mounts. One of these was a self adhesive mount, that we stuck on top of the anti glair shield (facing rear). For the rear mounted position (facing forward), I used the tube clamp on mount. I modified the mount and bolted it to a angle that was clamped to the threaded rod that holds the rear slider. I clamped the angle with washers and nuts on the threaded rod. The first rear mounting was on the rear luggage bulkhead, but it vibrated too much.
I haven't any photo's, but I'll try and remember to take some for posting.
I had the prop balanced the other day which has reduced vibration in the airframe. So I'm interested to see how future video's turn out.
Old 09-06-2011, 07:34 AM
gnuse's Avatar
gnuse gnuse is offline
I have just tried out my new camera. After watching a lot of videos and wondering how they did it; I just searched, read, and spent some money. Here is a link to my first attempt. I used the helmet mount that comes with the Drift HD170 as was mentioned on this site. I also have never edited a video, so I just chopped away until it met YouTubes requirements. I had no sensations in flying with the camera on the right wing. I will be moving it forward one screw for the next flight. When I did this flight I had no idea how to do anything with the camera other than rotate the lens and turn it off and on. I will read the instructions and see if improvements can be made. The camera was on 720p and that seems to have produced good results based on the time of day and speeds. There was some of the dreaded "Jello" effect turning final and the landing speed appeared faster than it was. I am thinking the plastic mount may be flexing due to the drag of the camera, but only slightly. It was an easy process to mount that took two minutes.
http://www.youtube.com/watch?v=ueXKbWCwC5k
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 09-06-2011, 11:08 AM
gasman gasman is offline
Maybe wrong link??????
Old 09-06-2011, 11:58 AM
gnuse's Avatar
Oops, link from a friend in Germany.......Thanks, I fixed it.
George
Old 09-06-2011, 03:19 PM
You did well for your first vid. You got about the same amount (possibly less) of shake/vibration as we do with ours (inside or outside). And yes, all goes smooth when you pull the power back.
As I mentioned earlier, I'm looking forward to see if there is any difference now the prop has been balanced.
Old 02-12-2012, 08:59 AM
WAM120RV WAM120RV is offline
Default Sony
Does any one have any experience using Sony or JVC cameras, I have my eye on some at our local Costco.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 02-12-2012, 01:19 PM
revenson's Avatar
revenson revenson is offline
I've got the Drift HD and have begun to try it out. Have not had success hooking it up to headphone output. Sound is garbled. I wrote Drift and they said it will be garbled if a stereo source is used. Mine is. So I tried a stereo to mono plug but still get garbled sound. I've written them again to see if they have any other ideas. Sound is fine, though, with their external mic.
Roger, 7A, N374RS, Tucson
