Old 09-01-2011, 01:16 PM
7dayflier 7dayflier is offline
Default DG repair-experimental?
I came across an "elderly" Edo-Aire DG stored on a shelf. The spring which returns the slew knob was not working. Since it was essentially a discarded gyro, I removed the tape seals (the ones that threaten your life if removed) and discovered the mechanism very simple and, yes, the small spring for the slew knob was busted at one end.
I re-bent the hook end of the spring, installed it and taped/resealed the gyro. Everything "seems" fine. I'd like to install it into my vacuum system and see how it works.
A couple of questions:
1. Is this a "legal repair" if installed in a VFR only experimental aircraft and entered in the aircraft logbook, or are aircraft instruments necessarily repaired by FAA approved repair stations?
No instrument shop I talked to would even entertain the idea of selling me the spring. All insisted that the instrument was far too complicated and that a full overhaul was required. One shop opined that if all they did was replace the spring, they'd only charge me $110, but they were pretty sure I needed a complete overhaul.
2. Am I "legal" to manufacture my own replacement spring?
Thanks.
Old 09-01-2011, 01:26 PM
Mel's Avatar
Mel Mel is offline
Default Daytime VFR only!
You're free to do pretty much what you want on an experimental amateur-built aircraft. Heck, you can even build your own DG.
However, this instrument may not meet the 91.205 requirement for night or IFR flight.
Also, be aware that this information does NOT apply to any instrument that has to do with the altitude reporting system.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-01-2011, 01:34 PM
RV8R999 RV8R999 is offline
Default FAR 91.205
Mel - Curious why do you think this instrument doesn't qualify for IFR or Night ops under FAR 91.205?
Old 09-01-2011, 02:30 PM
Walt's Avatar
Walt Walt is online now
Not sure what Mels take on this is but in my opinion (for what it's worth) if you do a repair to a TSO'd piece of equipment and you are not authorized to perform that work, than the instrument is no longer "in operable condition".
91.205 states:
a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) for that type of operation, and those instruments and items of equipment are in operable condition.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-01-2011, 03:09 PM
Except a TSO'd DG isn't required. If I take a TSO DG, modify it, call it my own, then it is just part of the experimental nature of the aircraft. The Builder determines and certifies the equipment is operable and logs it accordingly.. my opinion only.
Old 09-01-2011, 03:38 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
What about all these glass-panel-only RVs flying around with no mechanical gyros... only a non-TSO'ed experimental EFIS? Are they "illegal" to be flown night VFR?
Neal Howard
Airplaneless once again...
Old 09-01-2011, 04:31 PM
Walt's Avatar
EAA did a pretty fair job of summing it up here: LINK
As for the DG, I guess if you pull off the ID plate and install your own (similar to what we do on engines) then that would be "OK"
A lot of gray area here with the FAR's and not everybody agrees on what's "legal". If I were buiding an IFR panel I'd want a back-up (TSO'd) attitude, altimeter and airspeed for legal and personal reasons.
Old 09-01-2011, 04:40 PM
jcaplins's Avatar
jcaplins jcaplins is offline
91.205 states:
I don't believe Experimental falls under the standard catagory.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 09-01-2011, 04:42 PM
Mel's Avatar
Mel Mel is offline
You are correct. That's why your operating limitations state that 91.205 does apply for night and/or IFR operations.
Old 09-01-2011, 04:45 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Or at least the OL's should state this...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
