Old 08-31-2011, 01:08 PM
prkaye prkaye is offline
Default sealing canopy sideskirts
My biggest air drafts in my canopy are through gaps where the side-skirts don't quite sit flush with the sideskin when the canopy is closed. Looking down behind the canopy rail (between the canopy rail and the sideskirt) there is quite a visible air gap. I tried putting some self-adhesive foam weather-stripping on the inside of the sideskirt, but as soon as I opened the canopy this got caught, wedged and pulled away, because the curved contour of the sideskirt changes in relation to the fuselage and the canopy rail as the canopy is slide forward or back.
How have you guys managed to get a nice tight seal here? Or is it too late now that my plane is totally finished and painted and i'm not about to start bending my sideskirts to fit tighter?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-31-2011, 03:10 PM
petehowell's Avatar
Default Hello? Bob Axsom?
Bob has the craftsman's way to do this - I'm sure he will chime in!
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 08-31-2011, 06:55 PM
The easy way is to slit a piece of foam pipe wrap lengthwise and drop it in the slot between your canopy rails and the canopy skirts after you close the canopy. It sucks right down into the gap in flight and seals things very well. You need to remember to remove it before you open the canopy, or it may get blown across the ramp by the prop blast.
A V-shaped piece of rubber with one leg glued to the side skirt and the other leg free to suck down into the gap *might* be a better, more permanant solution. But the pipe insulation does just fine for me on the 10 days a year my cockpit would be too cold otherwise.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-31-2011, 08:34 PM
Default OK, This works
prkye, when you open and close your canopy you notice the there is NO NATURAL parallel surfaces between the fuselage and the canopy skirts through the full travel of the canopy. The solution involves creating them. I submitted it several years ago and it was published in the RVator but the author (Ken Scott I believe) did not understand the fundamental design and got it wrong in his description! It is also in this forum in at least one thread (one started by Ricka I believe).
First I have no skirt overlap of the fuselage skin - the bottom edge is parallel with the plane of the canopy deck when fully closed.
Is there a surface in the fuselage that is parallel with the direction of travel of the canopy? Well yes there is - it is the curved outer surface of the extrusion (track?) on the left and the right canopy deck.
Now, if you added a structural member (rib) to the canopy side skirts with a surface parallel to the outer surface of the extrusion you would have a starting point for creating seals in the area of concern.
I made my ribs out of 3/16" aluminum bar stock bought from Aircraft Spruce. It takes some patience but It can be done with precision. I marked off the canopy decks outboard of the tracks in 1/2" increments. Then I measured the horizontal distance from the outer surface of the track to the side of the fuselage at every mark and recorded them with the distance of the associated mark from the front of the deck. Next I made a pattern out of file folder material (cardboard) with a straight edge and perpendicular marks at 1/2" increments and ... this get tedious so I'm going to cut it short. Layout the non-straight edge on the bar stock with respect to the straight edge using the pattern. Then I sawed out the two ribs using a hack saw (now I have a band saw and it would go much faster) and finish the sawed edge so that it fits nicely inside the canopy skirt at a location above the canopy deck that is the same as the height of the maximum width of the extrusion (track). Match drill the skirts and the ribs, dimple the holes in the skirts, countersink both ends of the holes in the ribs, double flush rivet the ribs to the skirts. Use the patterns created earlier to make oversized seals out of rubber sheet. Glue the seals to the bottom of the metal ribs with 3M yellow weather strip adhesive. They are below the maximum lateral extension of the extrusion blah blah blah. I also have some 1/16"x1/2" braces from the canopy frame to the shirts above the ribs.
Anyway don't expect to walk out to your hangar or garage and knock this job out in a day or two. It requires precision and precision takes time and you have to think about what you want to do and how it is coming along as you work. But for 7 years now my canopy does not leak - at all - and there are no canopy to fuselage abrasions or wear marks.
Good luck with however you decide to work the problem.
Bob Axsom
Old 09-01-2011, 03:33 AM
PIN 37 PIN 37 is offline
G"day Bob
Any chance of a picture of this arrangement. I am fitting my canopy now and was wondering about sealing?
Old 09-01-2011, 06:25 AM
riffelj's Avatar
riffelj riffelj is offline
Phil,
I didn't really understand from your post exactly what problem you're dealing with. Is it a draft coming into the cockpit, the appearance or the air noise from the gap? If it's a draft, then I may have an idea for you.
I struggled with drafts for quite a while. First I had air hitting the back of my neck from the slider bar. When I sealed that better, I had it coming in around the stick (bad area to get cold!). Then it was the flap pushrods. Then it was the rear bulkhead. They were driving me nuts (and for me that's a short trip!).
One day it dawned on me that maybe the problem wasn't the gaps; after all the cockpit isn't/can't be air tight. Air only comes in if the pressure inside is less than the pressure outside. Maybe the problem was that I was somehow generating a partial vacuum in the cockpit. The obvious opportunity for that was the high-speed air across the canopy-windshield cuff.
Sure enough I was able to slide paper between the canopy and windshield when the canopy was closed. It took me 5 minutes and some sticky weather stripping tape to get a better seal. Eureka! My problem was solved. Even tho there are gaps, the drafts gone. And I didn't have to repaint anything!
Old 09-01-2011, 06:46 AM
Thanks Guys.
Kyle, your trick would probably work, but i would probably find it less embarrassing to tell a passenger to wear a jacket than to have him stuff a piece of foam insulation down there after closing the canopy.
Bob - your solution would have been perfect if I'd done it before finishing and painting the plane, when it was still in the shop. At this point I'm not sure I have the patience to spend trying to do it without risking damaging the paint job.
Riffelj (no signature?), it is indeed the draft. I did try stick weather stripping, but as I wrote in my original post the problem is that this just gets pulled away or jammed as I open and close the canopy, precisely because of the lack of parallel surfaces during this motion that Bob described. I'm surprised you didn't encounter this problem with weather stripping. I guess you probably used much thinner stuff than I was using... maybe I'll try that if I can find some.
Sounds like this draftiness is just a minor annoyance I will have to live with for the relatively small amount of flying I do in the very cold months.
Thanks for your thoughts on this!
Phil
RV9A (SB)
Ottawa, Canada
Old 09-01-2011, 07:16 AM
Originally Posted by PIN 37 View Post
G"day Bob
If you look up Ricka's thread "Slider Canopy Sideskirt" I posted some photos there some time ago. I also made up a Power Point file several years ago that covers my approach to sealing the canopy. I will send that to you if you, have Power Point software to display the package, want to have it and give me your e-mail address. When I get some time I will try to remember to post some photo's here as well.
Bob Axsom
Old 09-01-2011, 09:31 AM
rwhittier rwhittier is offline
Default I would like the PP as well -please
Can you send it to rawhittier at aol dot com? Thanks.
Bob Axsom
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 09-01-2011, 10:59 AM
pkill's Avatar
pkill pkill is offline
Hi Phil,
Might not be too late to add a couple more braces to pull the skirts in a bit... Here is a good thread on the Slider Skirts
http://www.vansairforce.com/communit...ht=skirt+brace
Post #6 (with photos) Terry Frazier added a brace to pull the back corners in.
pk
