Old 05-08-2006, 11:37 AM
jchang10 jchang10 is offline
Default Purpose of Bolts in Aft Deck
For my own edification, I am curious as to the purpose of these bolts attached to the aft-deck, in figure 2 in the plans below. This is the -10 plans, but i'm assuming that these bolts are in other models as well.
http://www.myrv10.com/Plans/RV10_Plans_sec10-pg22.html
I can't see any purpose in ever removing these bolts, since the parts it attaches to are also riveted. Only other reason i can think of is for greater shear strength?
thanks for any insights!
jae
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 05-08-2006, 11:57 AM
tagold tagold is offline
Default they keep the tail on.
Jae,
These bolts carry the tail loads to the longerons, which in turn transfer the load to the skins. You shouldn't ever have to take them out. I wouldn't leave them out if I was you !
Todd
RV-10 #362
Old 05-08-2006, 02:06 PM
Default Thanks
Right, that makes sense. In all other cases using bolts so far, i could understand why a bolt was used instead of a rivet. Either it was for something that allowed removal later, affixed dissimlar metals together such as steel with Al or Al with lead.
Thanks for the input. I have these bolts torqued and sealed.
jae
Old 05-08-2006, 06:02 PM
TSwezey TSwezey is offline
Bolts are used for tension. Rivets are not as good in tension.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
