08-30-2011, 11:28 AM
recirculating heat
One thing I never liked about my RV was that the dual muff setup I have was good to only about 20 deg. F OAT.
To help with heat I've sealed up the cockpit on my Rocket very well to prevent air intrusions.
One thing I would like to do is make the intake air to the one heat muff I have take in cabin air instead of from the back of the baffle. To do this, I will have to have some kind of blower of adequate capacity.
Has anyone done this who might be able to point me to a lightweight and effective 12V blower?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
08-30-2011, 11:41 AM
Senior Curmudgeon
My Porsche 914 has a blower that is pretty close to what you are asking about. It uses two outlets that are very close to the size of the SCAT tubing we use in the aircraft.
No, you cant have mine.
Probably find them cheap at a wrecking yard.
Older VW aircooled bus should have a similar unit. Probably cost less with a VW label, than a Porsche label.
http://t3.gstatic.com/images?q=tbn:A...ZxM_Px6wwvuLXQ
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
08-30-2011, 11:58 AM
Have you considered/tried electric clothing? Works well and only requires a power outlet.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
08-30-2011, 12:14 PM
This little blower...
puts out such a good blast of air, that I have considered using it as a boost fan for fresh air through the NACA vent.
See post #15 in this thread. http://www.vansairforce.com/communit...t=53269&page=2
(edit: well, now it occurs to me that this wouldn't be a good selection since you're dealing with heated air.)
Sam Evans
RV7-A O-360 C/S
VAF#812
08-30-2011, 02:52 PM
I have...that would work ok on local flights in the winter months but the problem is when I'm somewhere warm, fly five hours back home again into the cold, its just something else that I would have to carry with me half way across the country.
I am intentending to connect the fan to the inlet side of the muff so the fan itself won't get hot. The end plates of my heat muff are welded onto the exhaust pipe, so the system should seal well since it will be pressurized.
N8155F C150 flying
08-30-2011, 03:08 PM
Great idea, Bob. Why didn't I think of that? Duh.
Like you said, below about 20-25* OAT it's like sitting in a refrigerator. After awhile, I get chilled to the bone, regardless of layering. It would be much cheaper to find a 12v fan, run the intake SCAT tubing to the muff and just recirculate the air than to add another muff in series. There's enough ambient leakage in my plane that fogging won't likely be a problem. Make sure you post what you find and how it works.
Dang ... why didn't I think of that?
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
08-30-2011, 03:33 PM
Volkswagen Blower
JC Whitney Aircraft Supply carries these for just under 2 airplane dollars ($185). Look for "ACC CLIMATE CONTROL 12 VOLT HEATER BLOWER KIT VW".
Gary Hall
F1 Rocket Evo under construction
Track Links: APRS
08-30-2011, 04:00 PM
for the lazy...
http://www-b.jcwhitney.com/12-volt-h...wx?filterid=j1
-Jim
08-30-2011, 04:05 PM
Marine supplies
Considering the hostile environment how about a Bilge blower. These things can move a lot of air and are made for a hot engine compartment.
Most of them are squirrel cages made for scat tubes in the boat hull
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
08-30-2011, 04:28 PM
Pooooner,
You can also pull pre-warmed air off the plate under cyl 3&4 to supply your muff insteade of off the rear baffle. I picked up another 30 degrees of allowable temperature from doing this. Im good to -10F before I need more clothing.
More pics here.
Kahuna
6A, S8 ,
Gold Hill, NC25
