  #131
Old 03-01-2016, 11:59 AM
longranger's Avatar
There are "tank dies" that dimple a few thousandths deeper to accommodate the sealant.
RV-7 TU 904KM (reserved)
Construction Log
Old 03-01-2016, 01:27 PM
tgmillso tgmillso is offline
Good call on priming the Z brackets now, given access to the back of the bracket will be difficult later. I think what I'll do is just tape off the surface to be fay sealed, hit up the rest of it, then peel off the tape afterwards. I think I'll leave the T-405 angle until I paint the exterior of the tank once it's complete.
Tom.
Old 03-02-2016, 04:21 AM
Good call on the tank dies also. Unfortunately that would be two weeks shipping to get here, so I'm going to drill out and reseal tomorrow the couple of proudest ones, and plough on with the the remainder as I hope to have these tanks wrapped up by the weekend. I think the next set of wings will be quick build, blisters or no blisters, as these tanks are a mountain of work. T.
Old 10-11-2016, 08:14 PM
RobB52 RobB52 is offline
Can someone explain the process of using a pneumatic sealer to apply the sealant? Do you have some sort of disposable cartridges you fill with proseal? How do you clean the gun? Do you shoot a uniform bead on the skin and ribs or just one side?
I still do not like the idea of using popsicle sticks to spread the sealant and am considering buying a pneumatic gun.
Rob
RV-14 Flying
EAA Chapter 343 (DTN)
Shreveport, LA
Old 10-12-2016, 05:01 AM
noelf noelf is offline
The "sealant gun" is similar in operation to a "calk" gun, except that the sealant gun is attached to an air hose. You fill the disposable cartridges with the sealant of your choice, load the cartridge into the gun, attach the air hose, and pull the triger.
The cartridges are available in two basic sizes, the screw on tips are separate as are the end cap plugs. These plugs are what push against the sealant to eject it out the tip.
Noel
RV-6A N6NF
tip-up
flying
Old 10-12-2016, 10:35 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Or buy a full cartridge in this form from AC spruce and it will fit right into the sealant gun.
I found the 3.5 oz size correct for the rear baffle on a single tank.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-12-2016, 10:56 AM
larrynew's Avatar
larrynew larrynew is offline
Default Semco Sealant Gun
Rob,
Here's my blog post about the Semco Sealant Gun. I would never build a tank without one.
http://larrys-airplane.blogspot.com/...alant-gun.html
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 10-12-2016, 12:51 PM
wirejock's Avatar
wirejock wirejock is offline
Default Proseal gun
Sorry, I can't resist.
Here's mine. Cheap. Yes, I actually used it and it worked. Syringes were modified by cutting off the ears and thumb loop. Once done, just toss them.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-18-2017, 11:01 PM
amaris amaris is offline
Default MEK Alternative
Such a great thread, thanks to everyone for their thoughts and experiences.
I'm getting ready to start the tanks. I live in California, if the name sounds environmentally hazardous, they have stopped selling it.
What are some good alternatives to clean the tank before prosealing and cleaning wet proseal off areas I don't want it on?
MEK, Toluene (I think anything ...ene have been banned, including xylene and naptha) are all not for sale in CA to the general public.
Allen Maris - 2020 Dues paid
7A - 544RV In Progress
Santa Ynez, CA
Old 04-19-2017, 12:53 AM
Default Automotive wax and grease remover.
At the end of the day what you are trying to achieve is an impecably clean, mechanically etched surface to bond to. Thus, what you hope to do is remove all wax and grease deposits. So long as you let what ever solvent you are using fully evaporate after the cleaning stage, from my perspective there should be no risk of it impacting your bond. I found out that builders in Europe were using automotive wax and grease remover as they couldn't source MEK, so I gave it a try. My tanks came up great and passed the manometer pressure test with flying colors. The only reservation is that I am still a few months away from flying, so I can't give you the long term test results. Perhaps the European builders can chime in here.
Tom.
