02-26-2015, 11:13 AM
Originally Posted by bddalm
Bill R,
Just wondering, do you have quick build wings?
Sorry missed your question. No it is a 4 and I don't think they exist for that model. On the other hand, I bought the project almost all built, holes have been drilled. So I suppose it could be considered QB, except that the previous owner spent 25 yrs getting it there
Scott Black
VAF dues 2020
Instagram @sblack2154
09-22-2015, 11:46 AM
What is the "easy" way to remove dry Pro Seal? I had to remove the wedge from my rudder and need to clean it now for a second prosealing attempt.
RV9 #92188 - Working on wings
09-22-2015, 01:39 PM
Proseal removal
There's a product.
Edit:
Polygone.
Check this thread.
http://www.vansairforce.com/communit...&postcount=125
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Reason: Add link
09-23-2015, 04:39 AM
Many thanks!
02-28-2016, 09:54 AM
Quantity of pro seal to mix??
Ready to seal my first tank and wondering if there is a general quantity of sealant to mix for the stiffeners, etc. Having a number in mind would make the first mixing go easier.
02-28-2016, 09:56 AM
Proseal
Vans sells the quart kits. Buy one to start then if needed order a second later. That way your second will be fresh. My 7a tanks took about one and a half.
Larry Larson
Estes Park, CO
Disclaimer
02-28-2016, 06:23 PM
I found that about 1 gram per inch of surface I was sealing was a good amount to mix up. Always had some extra. So if your in the waste no Proseal camp you could probably back that down to .8 grams an inch.
N17BJ
RV-7 Tip Up slow build
200HP IO-360-A1B
Hartzell CS
Working on wiring and Fw Fwd
Got my RV-7 tail kit for X-mas 2012
Guess the Wife's on board!!
Dues paid 3/11/2019
02-28-2016, 07:13 PM
Misunderstood
Thanks. I misunderstood the question. That sounds about right.
Larry Larson
Estes Park, CO
Disclaimer
02-29-2016, 12:08 AM
prime components?
Hi Guys,
So I've read through this thread and I'm not exactly sure the extent of priming I should perform before assembly. I'm not priming any alclad or internal components, but my concern is around T-712 z brackets and the T-405 angle. I would normally prime these non alclad components but I'm concerned about interaction with the ProSeal/MEK. I'm thinking the best approach to fully Fay seal the T-712 and T-405 followed by wet riveting, then priming these components after the tank is complete. Let me know if I'm off base with this one.
Tom.
02-29-2016, 04:36 AM
Thanks! Very helpful!! My scale doesn't do tenths of grams so I mixed up 1 ounce to see how it would go. Had enough to get the stiffeners on, but needed more to do a nice fillet seal around them. Then got the fuel cap flange and drain on. Unfortunately had to drill out 3 rivets on the cap. Not fun.
