  #91
Old 11-03-2013, 09:17 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
I used toluene, worked great and made it wayyyyy easier to work with. I was able to get it from a local shirwin Williams, but the had to order it. Cost me about $20 IIFC.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 11-04-2013, 01:02 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I've bought Toluene at ACE hardware, and it also seems Sherwin Williams sells it -
http://www.sherwin-williams.com/home.../toluene-r2k1/
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-04-2013, 09:28 PM
jarhead jarhead is offline
Originally Posted by todehnal View Post
Has anyone tried thinning proseal??
Used to use MEK to thin PS890 B1/2 and B2 enough to paint it on with an artist's brush. After changing divisions within the company (one where there was no MEK), I used acetone to do the same thing.
This was NOT for sealing fuel tanks or any other critical sealant job, just sealing external hardware (specifically, helicopter rotor head hardware) for corrosion prevention. If you really want proseal that's thin enough to brush on like paint, for a critical job like fuel tank sealing, you need PS890 A1/2 or A2.
PS890 Class A data sheet
source
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
Old 11-04-2013, 09:30 PM
EDog EDog is offline
Default Thanks
I just read all 92 posts on this topic. Thank you Rick and everyone else for the great breakdown. I feel 100% confident on starting my tanks this week. I love this site!!!
RV-8, EMP complete. Skins on wings, tank time.
Old 11-18-2013, 09:45 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I got tired of searching for this thread every now and then, so I have made it a "sticky".
Just seems right that a thread about porseal be sticky
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-18-2013, 10:16 AM
fatherson fatherson is offline
Talking
Thanks, Mike. I just spit my morning coffee all over my iPad. Of course, it's black and thick as . . . well . . . you know. You just caught me of guard I guess. :-)
p.s. good call on the thread: it's one of my top-10s.
Stephen
Stephen & Tyson Humphrey
father-son team building new lives and an RV-9
VAF Donors: 2008 to 2014 * Friends of the RV-1
Old 02-15-2015, 12:21 PM
sblack sblack is offline
Having trouble shooting rivets wet. Should i just be putting a dab in the hole and keeping the tail of the rivet clean until after bucking? Right now i have the stuff all over the rivet and the bucking bar goes bizerk! Also, what bucking bar works best in a tank?
Thank you to all who have added to this thread. i would be lost without it.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 02-15-2015, 02:15 PM
blueflyer's Avatar
blueflyer blueflyer is offline
I too used this thread as my guide to sealing my tanks. It is slow tedious work, but mine came out leak free. I dabbed the dimple full of proseal and then inserted a rivet. I didn't have any trouble bucking the wet rivets. I used a tungsten bucking bar. Maybe your gun pressure is too high?
Old 02-15-2015, 04:00 PM
wirejock's Avatar
wirejock wirejock is offline
Default Proseal rivets
Same here. I did have to wipe off the surface of the tungsten bar occasionally.18-20 psi on my Sioux 3x.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-15-2015, 07:18 PM
N546RV's Avatar
N546RV N546RV is online now
Same here, I didn't really have any issues with the bucking bar. I did, however, have issues with the mushroom set sliding around. I'd been just using a plain mushroom set up to that point, but I bought one of the ones with the rubber ring for the tanks, and it worked much, much better.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
