08-28-2011, 11:40 PM
Sealing a 1" hole in firewall.
Ok, so I've pulled the vacuum pump and all associated equipment and I'd like to seal the hole.
I'm thinking I have a few options:
A.) A stainless patch riveted into place
B.) A simple plug from the aviation isle at Lowe's
C.) Reinstall the line splitter and AN cap it.
Any suggestions?
08-29-2011, 12:04 AM
A...........................
08-29-2011, 12:44 AM
Seems like a good idea, but all the A&P's I keep talking to don't recommend it.
08-29-2011, 06:36 AM
Why is that?
Dan Horton
RV-8 SS
Barrett IO-390
08-29-2011, 07:40 AM
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
I recently pulled my vacuum system and had to plug a hole a bit bigger than 1". I bought two oversize steel washers and sandwiched the firewall with them using a 5/16" bolt and a steel locknut; cheap and functional  Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
08-29-2011, 08:06 AM
A.
I just put 2 patches in my firewall from a rewire and vacuum pump removal. Put some Proseal or even high-temp RTV in between and rivet them on.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
08-29-2011, 08:11 AM
I agree with this, easy to do and bullet-proof.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
08-29-2011, 08:35 AM
Why not (B)? - with a suitable sealer of course.
The steel plug is just as fireproof as the thin SS you would patch with, and would look neater too....
It is also Vans solution on the -A model hole for the nose gear leg bolt hole.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
I bought the stuff to do the same but was worried the solution would find itself not centered at some time resulting in leaking fumes into the cockpit. How did you ensure it would remain centered over the hole besides tightening the bolt?
From Rosie: I used a permanent marker to mark the washer location and I put a couple of torque-seal stripes on it as well. Also, I used fender washers (way oversize) so even if it moved, the bolt would hit the firewall hole edge and the washers still cover the hole. I look at it every 50 hours when I change the oil (so far have 122 hrs with no movement)
Sid Lambert
RV-7 Sold
08-29-2011, 09:10 AM
I've patched many holes in the -8's firewall and go with "B" whenever possible. You can peen the tabs over to make the installation permanent if you're worried about security. RTV seals out the fumes too. Nice, neat fix.
I'll rivet a patch only on the really big holes like where the heater box was.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
