Old 08-27-2011, 09:58 AM
rapid_ascent rapid_ascent is offline
Default Elevator Rod End Mounting
So I'm about to attach my elevators to the HS. I have partially installed the rod end bearings into each elevator with a locking nut as shown in the drawings. I have not threaded them in to the specified depth yet. I'm just wondering why there isn't a washer under the lock nut on these. I hate to tear up my primer when I lock it down. Have most of your built per the plans or did you add a washer? I'm curious as to what is the standard way of doing this.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-27-2011, 10:20 AM
aarvig's Avatar
aarvig aarvig is offline
I just built mine to plan specs. There might not be enough room for a washer and the jam nut after your depth is set...I have to look at mine to be sure. I just tightened it down with blue loc tite (per Joe Blank at Vans) and brushed in primer to touch it up...left it at that.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 08-27-2011, 10:36 AM
Default Ray
Installing a washer before the jam nut would negate the jam nut's use. We are looking to bind the two nuts together by applying torque,
so neither nut can spin in either direction. So, no washers.
Regards.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 08-28-2011, 02:27 PM
flion's Avatar
flion flion is offline
Lorne is exactly right. If you want to preserve your primer, lightly prime around the nutplate opening just before adjusting the rod end and tighten down the jam nut while it is still wet. You should not have to remove or re-adjust these once you lock them down. Don't lock your rudder rod ends down until the VS is on the fuselage, but the same advice applies there. Locking them down on wet primer will give you slightly better grip when it cures.
EAA Technical Counselor #5357
Old 08-28-2011, 06:48 PM
Guys,
I get the double nut arrangement for locking nuts. How does the really work? I presume it is because two nuts when locked together get wedged to some extend and put some sort of force on the threads that makes it harder for the nuts to separate.
I'm not sure I get a nut locked to the spar with the nutplate on the other side as being the same. If the double nut case is really due to the force that is applied to the threads then I'm not sure how a washer would make any difference. Maybe I'm just not looking at this the right way.
Either way I'll do it per the plans and live with the primer issues.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
