Old 08-27-2011, 02:56 PM
aerofurb aerofurb is offline
A couple of pictures of our dual SkyView installation (in the process of ground runs, not yet flown).
My 3 analogue instruments are a requirement for the UK:
UMA 2-1/4" ASI (40-160 kts)
Airpath C2300 Compass
FALCON ALTN10MBF-2 altimeter (single sweep 0-10,000ft....!)
ASI is plumbed with the pitot on the right and static on the left (gauge in the panel and viewed from the pilot's seat). Static T-piece also feeds the altimeter.
Jerry Parr
England
Ex RV-12
Loving Rotax....
Old 08-27-2011, 03:11 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Don't feel bad about the UK requirements, I am putting in the same analog instruments in with my Skyview. I like the way you have mounted them, looks very nice.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 08-27-2011, 05:16 PM
AltonD's Avatar
AltonD AltonD is offline
Originally Posted by AltonD View Post
I don't know if the RV12 guys can use them, but the Pitot-static fittings sold by Stein are the best. You push in the tube, done, zero leaks. Passed my IFR cert first time, with zero leakage.
Do get the tubing cutters to make square cuts.
http://www.steinair.net/store.cfm?tlcatid=43
All the fittings with the male 1/8" NPT should screw right into all of your instruments.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 08-27-2011, 05:46 PM
gtmule gtmule is offline
Be VERY careful screwing the fitting into the instrument. I once broke a UMA ASI by over tightening the fitting. The Stenair/Mcmaster fittings are GREAT. Don't bother with the cutter though, a sharp knife or scissors work fine, the tubing/fitting connections isn't really THAT sensitive to the cut.
