08-23-2011, 05:58 PM
lubricating brake caliper pins
It was recommended that I lubricate the guide pins on my break calipers when I have them off for servicing.
I have read on other threads that the Cleveland folks say NO GREASE.
I have some "synthetic break lubricant" that i got from an auto supply place that is advertised to be suitable for all break components, including pins.
I also have a tube of boelube - the white waxy/flakey dry lubricant.
Which would I be better to use on those break caliper pins?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
08-23-2011, 06:38 PM
Graphite powder.
Works great. Keep it on the pins.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
08-23-2011, 07:38 PM
I use the dry boelube...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
08-23-2011, 08:32 PM
You could use a nickel type anti-seize, but I prefer to see them dry & scotch brite cleaned instead. Any lube will collect brake dust & dirt which will form a nice lapping compund. Maybe if I lived in a harsh rust area I'd feel different
Actual repeat offender.
08-23-2011, 10:01 PM
I scotch brite the pins...clean the holes, and apply a THIN coat of copper anti-seize. I've found that this method works extremely well, especially if wheel pants cover the wheels.
08-24-2011, 12:24 AM
RTFM
Cleveland does say no oil or grease, but this is the exact paragraph -
2 Slide pressure plate with new lining over anchor bolts and install brake
caliper into torque plate. Lubricate the anchor bolts with a dry film lubricant
(Appendix B, Section B3) specified for your climate environment:
amphibious/extremely wet or non-amphibious. DO NOT USE GREASE OR OIL.
These materials will attract dirt and enhance the wear of the anchor pins.
And the B-3 section
Anchor Bolts/Torque Plate Bushings
Amphibious Environment
Lubriplate X-357 Extreme Pressure Moly Lubricant
Non-Amphibious Environment
Silicone Spray
Dri-Slide? Multi-Purpose Lubricant
LPS Force 842? Dry Moly Lubricant
The manual is here and is worth a download even if it is 15 MB...
http://www.parker.com/literature/Air...AWBCMM0001.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
08-24-2011, 07:39 AM
This looks like it might be a good choice... jig-a-loo graphite extreme lubricant
http://www.jigaloo.com/us/e_products...te-extreme.php
Graphite Extreme is a serious, fast drying, ultra-thin high performance graphite-based lubricant that can be used in extreme temperatures from -99?F to 986?F.
Especially useful in dusty, dirty conditions where greaseless, oil-free lubrication is required and it will not pick up dust or grit.
Phil
RV9A (SB)
Ottawa, Canada
