05-09-2012, 08:47 AM
BTW, when you get that nasty UHMW tape off, use this 3M paint protection film in its place. It won't yellow, and will likely last the life of the plane. And if you do need to remove it, it will come off easily for up to 8+ years in my experience. Good stuff.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
05-09-2012, 09:26 AM
Vince- YUP! I've had webpage for your 4" tape laying on my desk for a month to remind me to order some. I measured the old tape that's installed on my wings and it was 4". Is 4" the most popular for wings and/or is that what you recommend?
Robert Kramar
Gilbert, Arizona - Vans RV-6A
- Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
- Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
05-09-2012, 11:21 AM
This may have been posted in the previous thread but just in case it wasnt. Apply the teflon tape to the inside of the upper trailing edge of the wing along the full length of the flap. Do not apply to your flaps.
Pat
05-09-2012, 11:32 AM
VAF Moderator / Line Boy
Pat
I know a lot of folks are doing that Pat, and it certainly solves the problem of visible, yellowing tape. My concern, however, is that the tape tends to pick up very fine grit, and the scraping action against the mating surface then creates scratches. With the tape on the flaps, the tape gets scratched (as does the underside of the wing skin). With the tape on the underside of the wing skin, the scratches are going to go into the paint on the leading edge of the flap. Personally, I would rather replace the tape than repaint the flap when it gets ratty - next time, I am going to try Vince's tape instead of the UHMW.
As usual, folks should make their own decisions - none of this will make your airplane fall out of the sky.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-09-2012, 12:29 PM
Paul is correct. It is far easier to simply replace the tape on the flap than to polish scratches out.
A typical RV uses the 4" tape, about 10' long since the flaps are 5' long on most RVs. RV-10's are longer.
I put this stuff on my Rocket flaps in 2003 and it still looks like new. I put it in various other spots, under fairings, etc. and can vouch that you really can remove it many years later with no problems.
And it's just not that expensive!!!! A $25 piece will cover the flaps. Compared to the $4000 (or more) that a typical paint job costs, it's chump change.
Vince Frazier
www.f1aircraft.com
05-13-2012, 07:51 AM
I've built three RV's without that problem. Maybe I have just been lucky.
Pat
05-13-2012, 09:07 AM
Kinda depends on how much grit is in your area and how many scratches/scuffs you can tolerate.
The PPF, properly installed, is virtually invisible and practically bulletproof.
Vince Frazier
www.f1aircraft.com
02-19-2015, 12:15 AM
This is a thread SO WORTHY of bringing back to daylight.
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
10-16-2016, 10:26 AM
Link ?
The link didn't work for me. Is the PPF a 3M product? I may do this as part of my inspection this year. Starting to look a bit yellow and peel at the ends.
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Reason: Typo
10-16-2016, 10:41 AM
Eraser
I'm getting ready to use the eraser to get the adhesive from my wing walk grip strips off. I'm replacing the the three strips with the Vans rectangular strip with the model number on it.
Fingers crossed.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
