Old 08-22-2011, 06:07 PM
Mark L Mark L is offline
Default Countersinking Fiberglass Fairings and wingtips
I was wonder how other builders have approached countersinking fiberglass fairings and wingtips to achieve the most consistency. I am going to countersink fairings to accept dimples for #6 screws; countersink fairings for #6 screws w/ 100-degree countersunk washers; and countersinks to accept nutplate rivets sometime in the future. Is it easier to use a deburring bit and just countersink by hand to accept the hardward? Is it more consistent to use a bit w/ a cage? Is a backing plate with a hole for the pilot needed w/ a machine-countersink cutter? How hard is the fiberglass on the cutters? What about the need for soft AL rivets for attaching nutplates to fairings?
Mark Lancaster
RV-7A N530L Finish Kit
Old 08-22-2011, 06:23 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Dremel
Use a Dremel with a tapered stone bit. Check the articles on the left side of the opening page for "wing tip install." There is info there on how to countersink the glass.
Don't dimple till you match drill the glass!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-23-2011, 05:50 AM
Default My approaches
In experimenting to find the fastest tip I have made quite a few of them. I use #8 screws and a lot of them (just under 50 per tip) so my sizes are different. My airplane is a RV-6A so even my stock tips may be different than yours.
I was starting to describe my process which is very methodical to assure no gaps anywhere especially at the front end. Ah there I go again...
I dimpled the skin holes and initially countersunk the fiberglass with a proper size countersink tool. I counter sunk the rivet holes with the 3/32" countersink tool. The countersink tool cut the fiberglass cleanly with no problem in both instances. From what I'm told the fiberglass cutting dulls the cutter faster than metal cutting but it hasn't affected my work yet. If it does some day I will buy a new cutter.
On my first set of tips I was concerned about the strength of the platenut installations and I decided to back up the fiberglass with 0.016" aluminum.
As I developed my racing tips I had the "already drilled and dimpled wing skins" to deal with so the relatively precise match drilling process with clecoes in every hole had to be modified. The precision is still pretty good but it is not "slam dunk" simple. Through this effort I learned a few things for my application:
- A 3/8" hole in the fiberglass, after the platenut mounting holes are precisely located, works just fine for accepting the wing skin dimple - no countersinking required.
- No aluminum backing strip is required even though I change my tips from short range racing, to long range cruising configuration several times each year.
- Floating platenuts can be installed in place of the fixed dimpled platenuts and they will compensate for locations where a screw can be installed but it binds against the edge of the dimpled wing skin hole. The mounting hole spacing is the same and if you drill a rivet out and damage the fiberglass rivet hole you can install a local aluminum backing strip as part of the platenut installation.
Bob Axsom
