Old 08-22-2011, 10:24 AM
Ron B. Ron B. is offline
Default Van's black baffle seal material?
I'm trying to match the Van's baffle material to Aircraft Spruce's part number. I can't seem to find the exact match and this is the material I used on my Supercub . I only want to replace a piece one foot long by 3" so I hate to purchase a kit from Van's. Mine is the standard black. Of coarse my leftover piece is 11" X 6" and I don't want a splice.
Thanks Ron
Old 08-22-2011, 12:20 PM
Default Van's sells the seal material by itself
I went to the online store for Vans and found this when I did a search for baffle:
Replacement Airseal Fabric
AIRSEAL FABRIC 12X56 more info $41.00
with a more info link to:
Part Number = AIRSEAL FABRIC 12X56
Price = $41.00
Quantity
I did the same at the ACS site and found this:
T-8071-3 Black Silicone Engine Baffle 1/8"x3"x9'
This is your best option when it comes to replacing those worn out Silicone Engine Baffles the T-8071 & T-95182. FAA approved replacement Engine Baffle. This material is easily identifiable by its textured finish and it is available in a 1/8" thickness. The key component in making this Engine Baffle a superior product is it's 32oz fiberglass reinforcement mat, it also boast a -60 to 550F temperature range.
I have difficulty getting to the hangar right now and I may have thrown all of my scraps away when I moved but if you like I could see if I have 3" x 1' piece laying around and send it to you free.
Bob Axsom
Old 08-22-2011, 02:06 PM
Thanks Bob, I did find the first item you listed from Van's. The second discription says it's 12" X 56" and it's $41. All I need is 12" X 3" but I hate begging it from someone. I was about to place an order from ACS Canada and I was hoping to get the same material. I think the black seal from Van's is about 1/16" to 3/32". It's a lot less than 1/8" for sure. Worst case senario is order what I call a large amount from Van's.
Ron
Old 08-31-2011, 02:48 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Like Ron, I too need a small piece of airseal fabric in order to make a flap that will cover all of my exposed FWF electrical misc (relays, limiter, ammeter shunt, etc). I only need a 8"x9" piece max and hate to buy a huge piece from Van's for $41. Any more suggestions on where we can find the same stuff in smaller quantities?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 08-31-2011, 09:19 PM
Default No Luck
On my weekly grocery run today I swung by the hangar and looked through my supplies and I don't have any of the old baffle material anymore. I'm really sorry. After we moved and I started working on the lower cowl baffling I started using the cloth reinforced red material in sheets and rolls. Good luck with your search.
Bob Axsom
Old 09-01-2011, 06:20 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default baffle material
I'll look when I get home tonight. I'm not real happy with the black that's included with the baffling kit. After three years it gets pretty limp and doesn't seal real good.
I'm replacing mine with the 3"x9' red silicone strip available at Acft Spruce for around $18. If I have a sheet of the black left, you can have it.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 09-01-2011, 06:25 AM
Super Moderator
Default BAFFLE
Thanks Ron
Ron, same as above message. I'll check this evening to see what I have.
Mike Reddick
VAF#153
Pilots N Paws Pilot
Ft Worth, TX (T67)
Old 09-01-2011, 07:37 AM
Remteck Remteck is offline
Default Van's black baffle material
Had to buy a complete roll to finish the job so I have some left over.
Ron and Steve, email me your mailling address at "grrrr02 at hotmail dot com" and will ship you the required piece by mail if you aggree to pay for shipping (material is free)
Cheers
Remy
Bought a RV-4 almost completed... after carefull inspection, had to re-do a few things Let's get this RV in the air !!!
C-G???
Old 09-01-2011, 09:28 AM
Thanks for the offer, Remy! It's much appreciated! I sent an email.
Steve
Steve M.
Ellensburg WA
Old 09-01-2011, 04:15 PM
Super Moderator
Default Material
I have enough for both of you guys even with a generous size overtrim and it's free, shipping included so let me know if either of you still need any.
Mike Reddick
VAF#153
Pilots N Paws Pilot
Ft Worth, TX (T67)
