Old 08-21-2011, 02:29 PM
SeanB's Avatar
SeanB SeanB is offline
Default Wings, safety wire and securing plumbing/wires
Looking for pics of the safety wire and wire/plumbing runs through the wing bellcrank and roll servo. How does everyone capture the third bolt with the safety wire in back? I've seen a few pics of this on builder's sites....got a few ideas.
Anyone else? Not a big fan of the sticky base for zip ties. I hear they can eventually come off. Seems to be a critical area for something to get loose.
If I use E6000 for the bases, any tricks to remove the double-sided foam tape?
Thanks!
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 08-21-2011, 08:12 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Here is how I secured the roll servo with safety wire - http://myrv10factory.files.wordpress...6/img_1184.jpg
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 08-21-2011, 10:32 PM
SeanB's Avatar
Thanks, Mark. I guess I'll need to practice the safety wire thing. Can't seem to get everything looking correct just yet. Usually ends up in a tangled mess.
SEAN BLAIR V7
2020 VAF SUPPORTER
Old 08-23-2011, 11:14 AM
SeanB's Avatar
Default Tried it
Okay..I tried the safety wire thing. It took a few tries and some frustration, but I think I got it figured out. Does everything look acceptable in the pic?
https://s3.amazonaws.com/expercraft/...3de0f14824.jpg
I hope to get a little better at this with practice.
Thanks!
SEAN BLAIR V7
2020 VAF SUPPORTER
Old 08-23-2011, 11:20 AM
bkthomps bkthomps is offline
I think the correct way to apply inspection lacquer is to the nut and the thread of the bolt that is showing, not the washer/surface- the entire assembly can rotate without a problem, it's when the nut begins to back off the thread that you have an issue
Old 08-23-2011, 12:49 PM
The safety wire looks right - all the strands tend to tighten the fastener.
And the goop looks fine, too - it covers the nut/bolt joint, which is what could unscrew.
Nice cotter pin bends, also.
Dave
Old 08-23-2011, 12:52 PM
Brantel's Avatar
Brantel Brantel is offline
I would use a longer bolt on that pushrod or go to a thinner washer on the head side. You need more threads than that showing on a nylon locknut. You don't want that pushrod coming loose and flopping around in there!
Safety wire looks fine.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-23-2011, 01:42 PM
SeanB's Avatar
Thanks everyone. I'll take another look at the bolt. Everything is as supplied, but I guess that doesn't always make it right.
SEAN BLAIR V7
2020 VAF SUPPORTER
Old 08-23-2011, 02:07 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
What's the 'rule of thumb'? two threads showing...if I remember right. It looks like you might have that?
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 08-23-2011, 02:35 PM
Dave
I was referring to the goop in this picture being inadequately placed
