Old 08-21-2011, 06:04 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Question
Out of shear curiosity and at the risk of being off-topic (as I know this only pertains to RVs), do military airplanes have to operate under the same rules when flying into and out of civilian towered airports? I see the exact same operations that the original poster described going on all day everyday at KAFW with military aircraft. Just curious....
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 08-21-2011, 06:08 PM
Default Perhaps surprising
Most people have no idea what an airplane called RV is. Is this some small elite group that is reported to be bashing RVs?
Bob Axsom
Old 08-21-2011, 06:46 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Just Curious...
Post #1 states "RV doing a low pass at about 100' " then Post #27 states
"a low pass at less that 100' AGL". What was the reference used for these quoted measurements? Why are they different? Maybe it was at 125' or maybe even 200'?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 08-21-2011, 07:36 PM
BuffDriver BuffDriver is offline
Yes, except that sometimes they have waivers to exceed speed limits. For instance the T-38 is waivered to 300kias below 10kft. In general, military aircraft are subject to all the same rules that civilian aircraft are when operating anywhere in the NAS.
Old 08-21-2011, 08:06 PM
RV8R999 RV8R999 is offline
I don't believe the low pass is the problem but the high-g pull-up at the departure end which cause the trouble, am I wrong?
Certainly the low-pass in and of itself can be a useful maneuver to verify landing and runway conditions. I WILL NOT land at a grass field I haven't been to recently without a low pass first... and often do this to uncontrolled fields when windsocks are hard to see from the air.
Old 08-21-2011, 08:25 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default High "G"
One of the posts talked about a "high G " pull up. How can they tell what G load was used? What constitutes "high" G, 5,3 or 6? I bet no more that 2 G was used, no more that a 60 degree bank turn requires to hold level flight.
A climbing turn to down wind is basically a chandel, a maneuver taught to instrument pilots or it used to be when I was trained.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 08-21-2011, 08:34 PM
Moondog's Avatar
Moondog Moondog is offline
Default Low pass
Wasn?t sure what kind of plane was taking off at the air field behind my house, wasn?t familiar with the sound. It was perhaps 500 AGL when I walked outside to check it out. Never climbed above 800? while making a lazy turn back to base. Lined up with the runway, then descended to probably 200? and accelerated to make what was obviously going to be a very high speed pass. At the tower, it nosed up into a climb that would have impressed a fighter pilot. I?d guess it was a couple of minutes before it disappeared into blue skies above me. As long as I could see it, it never leveled out. And no it wasn?t an RV, it was a B-52 leaving Ellington Field (near Houston) the day after an air show. Was it wise? Legal? Maybe not. But it was pretty cool.
Old 08-21-2011, 08:50 PM
Most likely doing a practice circling approach. It did a low approach because the runway isn't wide enough for our tip gear (unless you consider one foot per side to be adequate margin). It climbed like a bat out of **** because there is an abundance of extra thrust in the BUFF, especially when they are light weight, which he probably was if he was just leaving an airshow and heading back home. Glad you enjoyed the show.
Old 08-21-2011, 09:40 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Perception
Folks, this is a matter of perception. Is such an act necessary under normal arrival procedures? I will submit that it is not. It really doesn't matter if it is legal or not.
We never know who is hanging around a given airport. Why do something that can bring attention to ourselves? Notice I didn't say "negative" attention.
There are four factions involved. (Actually more if we wanted to take it farther) 1) Pilots 2) RV pilots 3) Non RV pilots 4) Non pilot public. We have heard recently from the AOPA forums that we (RV pilots) have established a less than positive reputation with non RV pilots. Right or wrong, deserved or not, it is there. I've heard it around our community.
The unknown is how the public views us. I'm sure they don't know the specifics of different aircraft, but they can view differences in behavior and procedures. As an example, I live at an air park. It is P19 in Chandler, AZ. Check it out on Google Earth. It is a very unusual air park in that it is very urban. We have large tract residential areas on 3 borders.
On one occasion, I was talking to one of these neighbors. He asked why, on occasion, do some airplanes look like they are landing but go down the runway "like a bat out of hell?" The question and the tone were clearly unfavorable.
Occasionally, a couple of our Glasair or Lancair owners will make make high speed passes. I'm not grouping them into plane category because I know the guys. Just mentioning the plane for the next comment. Point being that the Cessna 182's or Cherokee's don't do such passes.
Also, no need to pick nits on the altitude or the high G pull up. You know what he is describing. Both Glenn and I are medical helicopter pilots. We have done extensive autorotation training. Flare altitude is critical for survival. I will be willing to bet that we can accurately guess the altitude of an aircraft (AGL) below 200' within 10'. So in the original post, he mentions 100'. I could have been 90 or 110.' Again, don't get technical on the altitude.
In summary, in this time in history, we need to self evaluate our every action. If there is any doubt as to its appropriateness, DON'T DO IT.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-21-2011, 09:42 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default YEP
Well said Darwin.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
