Old 08-20-2011, 07:58 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Default Deburing Wing Rib Conduit Hole. Any tricks?
Anyone have a power tool they got that helped them with this? My conduit holes are 3/4" and my die grinder wheels are 1". If you found a Dremel bit, or some other tool that worked for you I'd love to hear about it. The prospect of elbow grease and Scotchbrite doesn't excite me.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 08-20-2011, 08:05 AM
philb philb is offline
I used the 1 inch deburring wheels/die grinder on nearly everything!
I always saved the "used" wheels when they got down to a smaller diameter for exactly tight quarters work like the conduit holes. Would have 3 or 4 partially used wheels at any time for this purpose. Nothing worked better.
Phil
Salt Lake City
RV10 FF - moving to airport
Old 08-20-2011, 08:23 AM
Sparky's Avatar
Sparky Sparky is offline
Default Royal Multi-Burr Tool
I used this Royal Multi-Burr tool for those and many other lightening holes etc:
http://www.averytools.com/prodinfo.asp?number=22022
I also used 1" Scotch Bright wheels whenever possible for larger holes and edges.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 08-20-2011, 08:43 AM
Greg Arehart's Avatar
Get a larger step drill (relatively cheap ones can be found at Harbor Freight and these work fine for this application) and you can either chuck it in a drill on slow speed (be careful not to enlarge your hole!) or turn it by hand to take the burrs off.
greg
Greg Arehart
N 7965A
Old 08-20-2011, 08:46 AM
bkthomps bkthomps is offline
i just use the next largest ring on the step drill and give it one or two turns on each side
Old 08-20-2011, 10:33 AM
Lemmingman's Avatar
Great idea Phil. That worked just fine. I had a few of those sitting around as well. Now the insides of the hole is nice a smooth.
I'll get a larger unibit when I go out next too, I hadn't thought of that and it might be better than burning up my wheels on the outsides of the holes. Does Hobby Lobby sell those? My wife just asked me to go there with her.
Gil Brice
Old 08-20-2011, 01:07 PM
Brantel's Avatar
Brantel Brantel is offline
I used about 30 1" scotchbrite wheels building my plane. Great stuff!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-20-2011, 06:55 PM
gib's Avatar
gib gib is offline
Default Burr Whips also known as Royal Multi-Burr Tool
Single Flute countersinks are great in a drill for smaller hole. Weldon makes a nice one. But I really like burr whips for large hole like lighting holes.
http://www.rjmeng.com.au/weldon.htm
