Old 08-19-2011, 03:32 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default Aviation Products Tail Wheel
I have the Aviation Products single fork tail wheel assembly on my RV4 and the wheel wears unevenly which causes issues with ground steering. Wondering if anyone has experienced the difference between the single and double forks and if the double helped with the uneven wear problem.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 08-19-2011, 04:20 PM
RV6_flyer's Avatar
Yes. The single fork bends and causes the tire to wear on one side. I bent TWO (2) and now have a double fork. Tire wears correctly now and has for years since going to the double fork. (2,507+ flying hours in almost 14-Yeats)
I do not think I DROP the tail hard on landing but the SINGLE fork still bends.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-19-2011, 04:36 PM
Toobuilder's Avatar
I'm running the single fork on my Hiperbipe and have never bent anything, despite 2050 gross weight and 114 on the tailwheel in the level attitude. This thing has to be much heavier than the -4. My buddy wore out several AP tailwheels on his -4 and they wore perfectly flat - single fork.
I have switched from the 6 to the 4 inch tailwheel on the HB. That model should have a much stiffer leg. It rides much more harshly on the ground though, as you would expect. Might be something to consider.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-20-2011, 08:52 AM
Snowflake's Avatar
Just a thought, but are you sure you have the right bolt/axle for the wheel? Maybe that's the part that's bending?
Having owned a Honda VFR I am totally in favour of a single-sided wheel supports... But most of the tailwheels i've seen built that way make me cringe from an engineering standpoint... They just don't *look* strong enough.
Rob Prior
Old 08-20-2011, 01:07 PM
N64GH's Avatar
N64GH N64GH is offline
I had a single the tire was uneven. Changed to a double on the advise of Gary Sobek (RV6 Flyer) and problem dissipeared. Got the fork from ACS took no time at all to change.
Mike Divan
N64GH - RV6,flying
Once an Airman always an Airman (SSgt 78-82)
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
Old 08-22-2011, 11:38 AM
vfrazier's Avatar
vfrazier vfrazier is offline
RV tailwheels and repair parts
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-22-2011, 01:17 PM
AX-O's Avatar
AX-O AX-O is offline
I sent mine (single arm) back to them and they sent me a new one (2 arms) for free. They are very nice people. I just told them about the problems that have been previously mentioned on VAF.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
