08-18-2011, 09:05 PM
Scotch Brite Wheel Question
Anybody got a trick to dress the grooves out of a scotch bright wheel?
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
08-18-2011, 09:17 PM
If you go to the EAA website and look in the Mutimedia area, they showed how to take the grooves out of the Scotchbrite wheel, I can't remember what grade of sandpaper on a board and run it underneath it for a little bit.
Longmont, CO KLMO
930KJ Reserved
Preview Plans 9A
Buying Tools
08-18-2011, 10:30 PM
Dressing Scotchbrite Wheel
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
08-18-2011, 11:05 PM
An old unwanted file should do it.
08-19-2011, 02:45 AM
I can show you how I fixed mine, Jeff. I ran into this same problem a few years ago. Here's what I came up with:
Both tools were running, of course, unlike the static picture. Further discussion, along with before and after pics are in my weblog here:
Fixing a Scotchbrite Wheel
08-19-2011, 07:13 AM
Basic gist of the EAA video
I went to Lowes and picked up a belt sander belt of the gnarliest grade of sandpaper they had. I dont remember the number. If you hold the belt against the wheel, all those grooves go away eventually. I needed a couple belts to get mine clean.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
08-19-2011, 09:12 AM
We put a video on youtube about how to do it. Look at the bottom of this page.
[Text here that was promotional in nature was removed by the owner of the forums. Non advertisers cannot use the forums as a promotional tool (rule #5 at: http://www.vansairforce.net/rules.htm). Answering a specific, technical question that can be verified with a source is of course allowed - and encouraged! ]
08-19-2011, 09:23 AM
Senior Curmudgeon
Borrowing Bruce's photo here,
I have to say I would not bother to smooth out the wheel at this stage of wear/grooving.
There is a lot of flat surface left to utilize, and to dress it at this stage is just a waste of usable, and expensive, product.
Like Stein would say, my $.02
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
08-19-2011, 10:31 AM
I agree. Mine's just about covered in grooves (5 or 6) and I'm starting to notice not having a good flat spot.
Those grooves do come in handy for edge finishing, though. One pass, instead of two.
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII, ATP
RV-7 in work (See my build log.)
Empennage...Done (except rebuilding the rudder.)
Wings...Halfway complete.
2018 Dues Paid
