08-20-2011, 01:27 PM
Originally Posted by nucleus
I had a problem the first summer with mine. I put another cooling tube to that pmag and really sealed up my plenum - which lowered my already good CHTs another 20 degrees.
Haven't had a problem since. I've been running an experiment where I ran the NGK Iridium (EIX) plugs on one and regular NGKs on the other - amazing difference when running lean. I am looking forward to running both pmags on EIXs.
In my opinion running auto plugs is a huge advantage.
Hans
Been running EIX plugs since Feb 2009, about 100 hrs a yr, ZERO wear, still cheap enough to toss a new set in once a yr.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
08-21-2011, 03:04 PM
Originally Posted by RV7AV8R
Regarding CHTs, I have not noticed much difference. Regarding power, it feels more powerful on take off with dual Pmags but that may be because I just spent a bunch of money on them
I had my right LASAR magneto fail back in June, and decided to replace the LASAR system with two P-Mags.
I have the same "feeling" and think I am getting a little better power on take off. I've also been tracking the centerline better too, but maybe that's not the Pmags.
So far I like them a lot.
08-23-2011, 03:56 PM
Any issues for those of you running auto plugs? Heard stories of the plug wires coming off in flight. Like the idea of cheap plugs with a hotter spark, but I like the magneto wires being screwed on even more.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
08-23-2011, 04:36 PM
no problems here
I have auto plugs on top with my light speed EI. I always check at oil change, but have not found a wire moved in 150 hrs. Some people talk about 'burping' them when you put them on. I don't do anything fancy, just wiggle it around as I press it on. No issues.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
08-23-2011, 04:48 PM
The devil is in the details
Hey Space Man Spiff, [love the avatar]
Like Steve mentioned above, the secret to getting automotive spark plug wires to stay on is to provide an escape path of the air which gets trapped inside the boot of the plug wire. [aka burping] If you do not do this, air gets trapped [under pressure] inside the boot. Time and vibration will cause the boot to slowly work it's way off of the spark plug.
Just had to deal with a customer who did his own "tune up" on a 1995 Ford van. 3 of his 6 spark plug wires had come loose because he did not know to do this.
Charlie
PS Watch out for the dreaded Gurl!
Reason: edited name
08-23-2011, 05:29 PM
ok so how did you provide an escape path? I have not heard this was a problem with auto-plugs..which I am using.
08-23-2011, 06:23 PM
Burp... scuse me
Pinch the sides of the spark wire boot as you wiggle it into place. You will hear air escaping as the boot slides into place. Ensure that the boot slides firmly into place.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
08-23-2011, 07:12 PM
Auto vs. Aviation plugs
Hey SIG600,
I went with the aviation plugs thinking the me thing - screw on would be better because of the security.
During the build process for one reason or another I had to remove and replace the plug cap many times.
Well, fast forward to about 20 hours of flight time....I go out for my engine run up before takeoff and find that I am dropping a cylinder! Scrub that flight!
I take the cowling off, start to remove the cap on the #1 cyl and what do I find? The cap cut the outer shield of my plug wire like a pipe cutter!
I plan to run aviation plugs until I have to replace them and then I will switch to auto plugs.
Other then that I do love the pmags.
Regards,
John Mastro
RV-8
08-23-2011, 07:35 PM
No issues in over 300 hours with dual P-mags. They clip on and seem to stay on, even with burping them.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
