Old 08-18-2011, 12:32 PM
Auburntsts's Avatar
Default Step Install
I'm in the process of installing my steps and the fit is pretty snug between the step and the mounting bracket. So much so that if I were to prime the exterior part of the step that goes through the mounting bracket or the inside of the bracket, there's no way the step will fit. I really don't want to remove any material from the step or the bracket, but I also don't want to leave it bare. What are my options for corrosion protection in this case?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-18-2011, 04:21 PM
flion's Avatar
flion flion is offline
Install it wet and touch up where any primer gets rubbed off going through.
EAA Technical Counselor #5357
Old 08-18-2011, 06:14 PM
Auburntsts's Avatar
Man, sometimes the simplest and most obvious solution is right there staring you square in the face. Thanks!
PP ASEL-IA
WAR EAGLE!
