Old 08-18-2011, 10:38 AM
DCat22's Avatar
DCat22 DCat22 is offline
Default FAA Changes the Avail of On-Line VFR Charts?
Quoting from elsewhere, with permission. Thought this was interesting...not sure if it will have any effect on experimental avionics that may use this stuff, iPad apps, etc... (Or at least, cost of those services that are far lower than Jepp. )
Originally Posted by rainsux
Just noticed this new notice on AeroNav's website:
"New Process: Next Editions will be available 1 Day prior to their effective date."
It only appears on the pages for sectionals, TACs & WACs:
http://aeronav.faa.gov/index.asp?xml...chartlist_sect
http://aeronav.faa.gov/index.asp?xml.../chartlist_tac
NEW:Updated info:
Just got off the phone with AeroNav. All their on-line content will be shifting to 1-day availability over the next few months.
Content will be avail earlier, for those that "purchase an Enterprise License." How much? Cost will be based on the qty of end-users.
> What was the availability before?
Usually 7-10 days. For VFR charts: Sometimes more. Sometimes less.
> And what happens if I buy an "Enterprise License" and re-publish the data
That's what I'm trying to figure out. The telephone call went from, "based on the
number of end-users" ... to ... submit all your questions in-writing.
What "Abby" told me:
- Early access (what has been "business as usual") will now cost money.
-Approval to redistribute will cost money, based on the number of users.
- There will be requirements for encryption of AeroNav content.
When I began asking clarifying questions, the only answer was, "submit your
questions in-writing."
-Rick Greer, VAF #2492
Old 08-18-2011, 08:51 PM
flytoday's Avatar
flytoday flytoday is offline
Default Last minute chart release...
As an example, if many XYZ software users attempt to download charts in a short period of time, because they expire in < 24 hours situation, then I'd expect significant server delays from XYZ and some download failures.
This is not good...
flytoday
RV7A - purchased flying 05/2020
RV6A - purchased flying 07/2011
