Old 05-06-2006, 10:58 AM
jlfernan's Avatar
jlfernan jlfernan is offline
Default Preferred cutting method
I'm getting ready to order my QB wings and am struggling with what is the best method for cutting the holes in the LE for landing lights?
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 05-06-2006, 11:22 AM
Alschief Alschief is offline
I used a Dremel Tool with a fiber disk. It worked fine.
AL Smith
N495AB
RV6 Wiring/FF
KEOS
Old 05-06-2006, 12:03 PM
Captain_John's Avatar
I second that!
After using the abrasive disk, I switched to the carbide side cutter and finished it off with the drum sander.
Would do it al over again the same way!
CJ
The experiment works!
Old 05-06-2006, 12:25 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Agree with above, except that I'd add to CJ's that I, of course, followed up then dremel drum sander with hand sandpaper, emery paper, and then scotchbrite pad. Turned out great, and the cutouts are actually pretty square, believe it or not!
Get as close as you dare to the final line in your initial dremel cutting disk cut. That will save you a lot of time with the drum sander. Just need to keep a steady hand though. As usual with repetitive tasks, first side took about 3 hours, the second took about 30 minutes and created a lot less anxiety. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-06-2006, 12:35 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Alternative
Of course you could use the wingtip type of light and skip cutting the LE.
h
Old 05-06-2006, 02:27 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Dremel Cutting Disks
I find this to be the best Dremel cutting wheel. The 2 inch diameter makes it much easier to keep square to the work and follow lines easier. It also gives a faster cutting speed.
It's not a Dremel product, but comes from House of Balsa.. most hobby stores should have it...
House of Balsa Cutting disk
It's far better than the puny 1 inch disks Dremel sells....
It's also great at cutting steel parts....
gil in Tucson
Old 05-06-2006, 02:51 PM
Rick S. Rick S. is offline
I'll second the HOB Tuff Grind disks, I've used them for years and never had one break or shatter. I've worn them all out. They are reinforced with a weave and worth every penny. Plus you get to make a trip to the hobby shop and see how inexpensive R/C airplanes are now that your building an RV!!
Rick S.
RV-10
Fuselage
Old 05-06-2006, 04:26 PM
N916K's Avatar
N916K N916K is offline
To get all the radii the same find a cylinder that's about the right radius and use spray mount to attach sandpaper to it. It makes getting all the corners the same very easy.
Cam
Santa Ana, CA
RV-9 at KFUL
Old 05-06-2006, 05:49 PM
scard's Avatar
scard scard is offline
Any you probably have a great selection of cylinders for finishing purposes in your toolbox full of sockets.
Scott Card
CMW E-Lift
Old 05-07-2006, 08:19 AM
ericwolf ericwolf is offline
Default Another Method
I used a fiber cut off wheel on the dremel also, but I didn't cut very close to the final line. Once the hole was (very) rough cut, I used my snips to get close to the line, then used drum sanders and files to get the rest of the way. I felt that creeping up on the final cut line with these different tools gave me the most control.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
