Old 08-17-2011, 02:47 PM
gib's Avatar
gib gib is offline
Default How can you tell the difference between a -6 and -7?
Being the new guy and just starting on the RV adventure my question is: "How can you tell different between an -6 empennage and a -7 empennage?" Thanks
BTW this best forum I have been on ever.
Old 08-17-2011, 02:57 PM
704CH's Avatar
704CH 704CH is offline
Its all in the Rudder..
Most RV-7s have the rudder where the counterbalance overhangs the Vertical Stabilizer. This is the Same as the RV-9
I think only the very first few -7's had the same rudder as the 6. Which doesn't have a overhanging counterbalance.
Thx
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
Old 08-17-2011, 03:01 PM
bkilby's Avatar
bkilby bkilby is offline
http://www.vansairforce.com/communit...2&postcount=22
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 08-17-2011, 03:08 PM
Mel's Avatar
Mel Mel is offline
Early -6 rudder had no counterbalance.
Very late -6 has the -8 rudder with small counterbalance.
Very early -7 had the -8 rudder as well.
Later -7 has the -9 rudder with the large counterbalance.
Wingtips also vary, but so many have been changed that you can't go by that.
If you are in the cockpit, look at wing attach bolts. RV-6 has bolts all the way across.
RV-7 has just a few on each side.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-17-2011, 06:26 PM
flion's Avatar
flion flion is offline
If you have only the empennage (in other words, you are buying parts or some such) then you should look at the plans. If the empennage does not have a plans set to go with it, do not buy it. If you are trying to tell RVs apart from the tail, the above will give you a fair guess but the surest way is to look under the horizontal stabilizer. There you should find a data plate with the model number. Even the guys who build a "John Doe 6A" rarely change the number designation; they just preface it with something other than RV or Van's.
EAA Technical Counselor #5357
Old 08-17-2011, 09:15 PM
gib's Avatar
gib gib is offline
Default Thanks
Thanks everybody, that helps alot.
Old 08-17-2011, 10:07 PM
RV7Aflyer RV7Aflyer is offline
Default The difference between an RV6 and a RV7
is that the RV7 is faster.
Just kidding....
Old 08-17-2011, 10:12 PM
gasman gasman is offline
Originally Posted by gib View Post
"How can you tell different between an -6 and a -7 " Thanks
The person that bought the used 6 has a LOT more money in his pocket!!...........
Old 08-17-2011, 11:00 PM
Snowflake's Avatar
Just kidding....
I hope so... I understand that with the same engine and prop the -6 will outrun the -7 by a few mph.
Rob Prior
Old 08-18-2011, 05:22 AM
sailvi767 sailvi767 is offline
I believe the 6 is faster also. I know the builder of my aircraft looked for a RV6 kit in 2004 even though they had not been sold by vans for years. He intended to use the aircraft in Sportsman racing so was not interested in a seven.
George
