Old 08-17-2011, 08:07 AM
prkaye prkaye is offline
Default 3M Sound and Vibration Damping Panels
I know there have been many, many threads on Firewall insulation, and I don't want to beat a dead horse, but I haven't seen any posts specifically about this product:
http://www.aircraftspruce.ca/catalog...pingpanels.php
The price is right, looks convenient to install (self-adhesive) and is fire resistant. I'm thinking of applying to cabin side of firewall to reduce noise and heat, and I definitely want anything I put on the firewall to be fire-resistant.
Any experience or opinions on this product?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-17-2011, 08:42 AM
rv9aviator rv9aviator is offline
That is what I used but I doubt it stops much noise. I did it because I thought it was better than nothing.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 08-17-2011, 09:26 AM
vfrazier's Avatar
vfrazier vfrazier is offline
http://www.flyboyaccessories.com/sto...=index&cPath=1
We have some similar items that work well and are less expensive to boot.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-17-2011, 01:25 PM
Larco's Avatar
Larco Larco is offline
I have used this product on several RVs and like it and recommend it. Of course there are other products available as well with many opinions as to what works best. Larry
Old 08-17-2011, 02:03 PM
DanH's Avatar
DanH DanH is offline
Polyurethane damping foam? Great on sidewalls, major hazard on a firewall.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-17-2011, 03:26 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Dan, I think it's this stuff -
http://multimedia.3m.com/mws/mediawe...--&fn=4014.pdf
3M says it's acoustic and say it's self-extinguishing, but don't seem to quote a temperature range.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-17-2011, 03:44 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Yes, but theres a difference between self-extinguishing and a material that will out gas and smoke when exposed to heat. The wrong material in the cockpit when heated can make visibility and breathing quite impossible without ever igniting.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 08-17-2011, 05:53 PM
DanH's Avatar
An FAR 25 airliner cabin wall insulation. Yep, it will self-extinguish within 15 seconds after you remove the heat source, which for the referenced "vertical method" is "a Bunsen or Tirrill burner with a nominal 3/8-inch I.D. tube adjusted to give a flame of 1-1/2 inches in height."
Put another way, it won't burn more than 15 seconds after you slap the snot out of Little Johnny and take away his daddy's cigarette lighter.
Firewall insulation it is not.
Here's the appropriate regs:
§ 23.1191 Firewalls.
(f) Compliance with the criteria for fireproof materials or components must be shown as follows:
(1) The flame to which the materials or components are subjected must be 2,000 ±150 °F.
(2) Sheet materials approximately 10 inches square must be subjected to the flame from a suitable burner.
(3) The flame must be large enough to maintain the required test temperature over an area approximately five inches square.
(g) Firewall materials and fittings must resist flame penetration for at least 15 minutes.
§ 23.1182 Nacelle areas behind firewalls.
Components, lines, and fittings, except those subject to the provisions of §23.1351(e), located behind the engine-compartment firewall must be constructed of such materials and located at such distances from the firewall that they will not suffer damage sufficient to endanger the airplane if a portion of the engine side of the firewall is subjected to a flame temperature of not less than 2000 °F for 15 minutes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-17-2011, 06:31 PM
az_gila's Avatar
Smile
Thanks Dan, I thought that was the conclusion...
Gil Alexander
Old 08-18-2011, 08:06 AM
bkthomps bkthomps is offline
i came in here to post let DanH tell you if it's the right thing or not, but he has beaten me to it
