Originally Posted by paulincapetown
Two pending issues for me and my new 7. I was told I need to purchase an inverted bracket ( may not be called this) to attach the crotch strap to the aircraft frame. Does anyone know if this is the case and what it is called? Will try Vans if i dont hear back from this post.
I was also advised to purchase a firewall - to stop heat etc in cockpit. Is this necessary and does it provide an enhanced safety feature if fixed to aircraft?
Paul
You are looking for a crotch strap kit. Van's sells them for $32 each,
last item down on this page. You'll need two. Before you buy, you might want to check with Van's. They weren't supplied with my kit, but it may be that they are now.
As for the firewall, surely your adviser must have been referring to firewall insulation. The kit comes with a firewall.
