Old 08-14-2011, 05:03 PM
Rob Erdos's Avatar
Rob Erdos Rob Erdos is offline
Default Firewall Forward: Aluminum versus Steel
I just noticed that my plans specify aluminum pipe fittings forward of the firewall. Why does Van specify aluminum (e.g. AN822-4D) when steel fittings are not-quite-as-cheap? Wouldn't steel fittings be safer?
Awaiting enlightenment,
Rob Erdos
Old 08-14-2011, 06:34 PM
vlittle's Avatar
vlittle vlittle is offline
I have an opinion (not necessarily correct). I try to use steel fittings when:
-the fitting is screwed into the engine or other expensive part such as the oil cooler. This should minimize cold welding.
-the fitting carries fuel (also use steel fitting on the fuel lines). It won't melt during the fire (maybe too late!)
Al to Al fittings work well, as do Al to Steel. Apparenty, steel to steel fittings need more torque because the steel is hard and does not seal as well.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 08-14-2011, 06:39 PM
frazitl's Avatar
frazitl frazitl is offline
Default I used
and recommend steel, stainless steel, or fire-sleeved flex lines for all fuel and oil lines and fittings FWFD. It's a little heavier and a little more expensive, but the time to burn through aluminum lines and fittings has to be much less than for steel. Sure, the oil cooler is aluminum, and so is the fuel injection servo body and spider. Nonetheless, fuel or oil under pressure spraying around FWFD scares me enough to take every reasonable precaution I can...
Call me chicken
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 08-14-2011, 08:27 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default steel fittings fwf
another reason to use steel fittings on fluid carrying lines firewall forward is that they are more crack resistant.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 08-14-2011, 08:57 PM
Wayne Gillispie Wayne Gillispie is offline
I am using what is provided, using fuel lube, torqing, and supporting lines properly. If we have a fire hot enough to melt alum ftgs with oil/fuel inside of them then your cowling/bottom skin/oil cooler/fab are in big trouble. All we can hope for is to be in the flare over a lake close to shore.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 08-14-2011, 09:35 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
That's been my take for a long time. I figure the cowling and windscreen won't be around too long. My plan is to shut off the fuel. I do have a steel fitting connected to the carb.
L.Adamson --- RV6A
Old 08-15-2011, 06:12 AM
Walt's Avatar
Walt Walt is offline
I prefer steel fittings FWF for the extra strength they provide, this is especially true on the engine which is subject to significant vibration.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-15-2011, 06:38 AM
DanH's Avatar
DanH DanH is offline
Exactly.
Engines shake. Aluminum has no knee in the SN curve.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-15-2011, 07:54 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
We can only speculate on Van's motives, but it could have something to do with the fact that aluminum fittings are considerably lighter.
Personally I'm skeptical that steel fittings help much with fire safety. Surely the rubber hose will be gone long before the aluminum fitting to which it is attached? Fatigue strength is another matter however.
Alan Carroll
RV-8 N12AC
Old 08-15-2011, 09:31 AM
jtrusso jtrusso is offline
Default Good timing
I was just going to ask this question.
I just bought into a share of a Glassair and all the fittings FWF on the fuel and oil lines are Al. All the fuel and oil lines are braided stainelss over teflon and fire sleeved, which is good.
I was wondering what the brain trust thinks about leaving it alone vs replacing with steel. I think it's better to leave them alone because the system has been tested and has no issues. If we tear it apart (assuming I could get the partner to go for that) we run the risk of building in a problem. Seems like the risk to reward ratio doesn't pan out. These lines were installed about 7 years ago when a new O-360 was installed.
I know, it's not an RV...but it's close enough for now. I'll still get that RV someday!
-John
Flying a Glasair I FT
Planning to build an RV...someday
