the mount system is especially versatile. the camera has a standard tripod socket with a small locking adapter that allows you to clock the camera in any direction when you snap it into one of the receiver bases. i used a standard helmet base fitted to the wing tip screw spacing. the lens and sensor on the camera can be rotated 300 degrees so you pretty much can frame any shot with any mounting position.
here is the camera on the wingtip for reference.
a closer shot you can see he helmet base
the screen on the Drift is great for framing the shot before committing to the flight.
this weekend i experimented with mounting and video with 10 flights... i have gads of video with some great results for mounting locations and perspectives. my favorite is the underside view with the wheels in the frame. i will post additional mounting points and some videos this week.
