Old 08-13-2011, 09:21 PM
CDBridgesRV7A CDBridgesRV7A is offline
Default Edge Forming Tool Question
Good Day Folks,
Does the edge forming tool sold at Cleveland Tools do the exact same thing as the edge rolling tool offered by Avery Tools and Aircraft Spruce? Are they in fact one and the same, just different method of utilizing them (vice grip vs. no vice grip)?
Chris
Old 08-13-2011, 09:46 PM
Phil's Avatar
Phil Phil is offline
That is correct. I have both and have found the Avery tool is a bit easier to use for me.
Old 08-13-2011, 10:50 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I have the vise grip type, it took me quite a bit of practice to get the hang of the darned thing, I thought the "twin roller" type would be easier to use.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 08-14-2011, 05:38 PM
bruceh's Avatar
bruceh bruceh is offline
I have both types and much prefer the vise grip version. Once it is set up to the right squeezing force it is quick and easy to use. Just go slow and don't let it veer off. A little squeeze is all you need to get a mild shadow of a crease.
Bruce Hill
2020 VAF donator
Old 08-14-2011, 05:52 PM
mburch's Avatar
mburch mburch is offline
I have both types, and in my own personal opintion they each have their unique purpose... the vise grip type is for making a perfect formed edge, and the other kind is for making scrap aluminum.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 08-14-2011, 08:52 PM
N223JH N223JH is offline
Chris, "Breaking the edge" is one of the real booby-traps in RV building. It needs to be done but is very easily over-done. (Don't ask how I know.)
On my second build I just hacksawed 3 different depths into a piece of hardwood and starting with the deepest, progressively worked to the shallowest putting a very slight "break" on the edge so it wouldn't pooch out when riveted. You can use a straight-edge and a flashlight to judge this. What you want to avoid is the "line" from a single pass through one of the commercial tools. Many of the RV's you see will have the lines visible.
Jim
RV6A
RV12
Old 08-15-2011, 10:05 AM
clevtool's Avatar
clevtool clevtool is offline
The tools work in different ways. Our tool (vise grip w/stainless rollers) has the angles build into the rollers to allow about a 14deg. bend. That is overkill for most applications. The edge distance is maintained by the flange on the rollers and measures 0.200" from the bend. The other tools (with rollers) keep the edge distance consistant by the location of rollers, but the angle is held manually by rotating the tool on two different axis. Keeping that angle consistent without stretching the metal is more difficult. However with these tools you can go around radius' where with our vise grip tool you can only do straight lines.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 08-15-2011, 03:58 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default But go slow!
One of the two stainless steel rollers on the vice grip style has a raised lip that keeps the rollers flush against the skin's edge. You don't need to tighten the vice grip tension much to use the tool...but if you make it too loose, you'll jump that raised lip right up onto the skin and dig a pretty good elongated dent into the metal:
http://www.mykitlog.com/users/displa...g=132367&row=2
I got some help from some experienced aviation sheet metal pros to stretch out and roll/pound the dent flat, then squeeze the area back to original shape and thickness (he owed me, and he made good). Everything matches up now, but if it didn't I would have simply bought a new skin.
Good luck!
Jim
RV6A
RV12
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 08-15-2011, 04:10 PM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default What Matt said.
Once you get the feel of it, the vise-grip tool is almost like cheating, it works so well. You do practise using a new tool on scrap before going after the real parts, don't you? And yes, I own both types.
William Slaughter
Houston, TX
RV-8QB
Old 02-04-2012, 10:18 AM
golfoscarwhiskey's Avatar
golfoscarwhiskey golfoscarwhiskey is offline
Default WD-40 Helps
There is friction between the edge of the wheel and the edge of the piece being formed. I apply some wd-40 with a rag along the edge of the piece and this makes pulling the vice-grip tool much easier. I make sure the piece is clamped down and pull the tool with both hands, one on the grip and the other on the end of the bolt holding the wheel. Darned near done before I figured this out.
Glen Wilcox
