08-13-2011, 07:46 PM
Looking for MIL PRF 87257 Brake Fluid
Hi All,
I am about to fill and flush my brake system. I was reading up on the subject and was referred to this very nice discussion by Grove Aircraft:
http://www.groveaircraft.com/fluid.html
They believe MIL-PRF-87527 is the best option for brake fluid and is fully compatable with their products.
I sent them an email asking where I could find it, as my google search has not turned up a source. They wrote back and said, use MIL-H-5606--the standard stuff that everyone has used for years and which their article says is too flamable and obsolete. Interesting that they would give a really good explanation for why 5606 is a bad idea and then tell me to use it.
Anyway, does anyone know a source for a quart or two of 87527? I would hate to have to infiltrate a miltary base to find it....
Regards,
Michael Wynn
RV 8 Finishing
San Ramon, CA
08-13-2011, 08:51 PM
I'm using Royco 782 in my Grove brakes. 782 is the Royco brand name for Mil-PRF-83282. I bought a gallon because I was never able to find it by the quart but skygeek now has both quarts and gallons listed on the website
I thought a gallon would be way too much, but I've had to bleed my brakes more than once and I'm glad I had the extra on hand.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Reason: added info
08-14-2011, 05:20 AM
Be very careful with 782
My buddy used Royco 782 in his -4 but had scratches on his arm from tie-wrap ends and a little of the stuff got in his blood and he spent several days in the hospital with a severely swollen arm and took quite a bit of meds....Doc said he could have died.
Use gloves around this stuff and do your best to not get any on your skin!
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
08-14-2011, 05:27 AM
Second the 83282 (Royco from Skygeek) for the higher flash point. Just insurance; there have been RV brake fires with 5606.
Dan Horton
RV-8 SS
Barrett IO-390
08-14-2011, 09:51 AM
Varient of Mil-H-83282
Originally Posted by mlwynn
Hi All,
They believe MIL-PRF-87527 is the best option for brake fluid and is fully compatible with their products.
I sent them an email asking where I could find it, as my google search has not turned up a source. They wrote back and said, use MIL-H-5606--the standard stuff that everyone has used for years and which their article says is too flammable and obsolete. Interesting that they would give a really good explanation for why 5606 is a bad idea and then tell me to use it.
Anyway, does anyone know a source for a quart or two of 87527? I would hate to have to infiltrate a military base to find it....
Regards,
Michael Wynn
RV 8 Finishing
San Ramon, CA
Michael,
A quick search shows that Mil-H-87527 is a variant of Mil-H-83282. It has improved low temperature viscosity. Since Mil-H-83282 is good down to minus 65 degrees Fahrenheit, do you "really" think you need the added capability? Sounds like this new fluid was developed for military use in arctic regions. Are you planning on going to work for Buffalo Airlines??  See
http://en.wikipedia.org/wiki/Hydraul...Specifications
Charlie
08-14-2011, 10:03 AM
+3 for 2 qts 782 from skygeek. Cans had some good dents but no leaks.
Same with any cleaners, used motor oils...always wear gloves. I buy them on amazon by the case...Lightning nitrile gloves.
Good judgment comes from experience, and a lot of that comes from bad judgment.
08-14-2011, 10:50 AM
VAF Comes through again
Thanks guys,
I knew there was going to be a place to find this stuff
Regards,
Michael Wynn
11-14-2011, 04:18 PM
Mil-H-87527
Anybody found a source for the newer brake fluid? It appears to have better viscosity at lower temps and, well, I have lower temps about now. First time fill, so I want to try to find this stuff, within reason.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
11-14-2011, 04:19 PM
Correction, MIL-PRF-87257
The correct spec for the newer brake/hydraulic fluid is above.
Bryan Douglass
RV-10 N242BD
