I filled over mine and used a method that Rosie advised me on. I filled the gap and pop rivet heads and then used a strip of 1.45 oz "deck cloth" (very thin, lightweight glass cloth from Spruce) over the joint. Feather filled that out. Worked great, no cracking or problems in 889 hours and counting. There is, however, one spot (on the bottom, fortunately) where the gap made itself evident...and that's where I inadvertently sanded through the very thin glass. If you're careful not to sand through it, I don't think you'll have a problem.
Dan Checkoway RV-7
