Old 08-12-2011, 08:27 AM
albertaflyer albertaflyer is offline
Default Short and soft field procedures RV-6A
Hi,
Just wondering what most people are doing for soft field and short field procedures in terms of flap settings etc. For takeoff and landing.
Old 08-12-2011, 08:47 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Originally Posted by albertaflyer View Post
Hi,
Grab the search feature and drop in short field flaps and have a look at the gazllion posts on this very topic. Hit the posts button instead of the threads and you will see many many posts on the 6a, and other planes that will provide you with what folks are doing.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 08-12-2011, 09:16 AM
Vern's Avatar
Vern Vern is offline
Default RV-6A soft/short field ops
Use caution as it is easy to over-rotate and get a tail tie-down or rudder bottom.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 08-12-2011, 01:34 PM
pierre smith's Avatar
Default Hi Tony
Our 180 horse -6A got off so quickly, even with a FP Catto pitched for cruise, that we never found a strip so short that we needed to do a short field takeoff....it automatically does them!
Short field landings should be full-flap landings and it'll do them under 1000' easily and better yet with practise. We got slower and slower until there was very little cushion left during the flare and you sorta "splat" onto the runway.
IIRC, our approach speed was around 70 MPH but find your own because airspeed indicators and different airplanes don't have the same indications. Work down a few MPH at a time, carefully controlling your airspeed until there is little to no floating during the flare.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 08-12-2011, 01:43 PM
Toobuilder's Avatar
With the 8 and the 9A, I've found that you can get it so slow (and steep), that a well timed blast of power will take the place of the roundout. Make SURE to time the blast of power right, because there's nothing left in pitch to arrest the descent. Takes a bit of practice to work into this.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-12-2011, 04:48 PM
Thanks for the info guys. I did find that I drug the tail tie down once when doing soft field.
Old 08-12-2011, 04:50 PM
Is it better to leave flaps down to help keep the weight off the wheels until you lost most of your ground speed?
Old 08-12-2011, 05:40 PM
Mel's Avatar
Mel Mel is offline
Default My home field is 1500'.
Some consider it short.
I use 15? flap for take-off. Notably short than "no flaps".
For landing, I use 70 mph across the fence, full flaps (38?) and dump them immediately on touchdown.
Just my procedure. Worked well for me for a lotta years.
Use what works best for you.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-12-2011, 07:53 PM
vlittle's Avatar
vlittle vlittle is offline
Many years ago I asked my flight instructor what the procedure was for a short, soft field landing.
He called that a 'crash' and would not recommend it.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
