Old 08-08-2011, 03:12 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Battery Relocate
I'm nose heavy and am considering moving the battery to rear of the baggage compartment before adding lead ballast to the tail. I think others have done this. Any suggestions or links? Or plans?
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 08-08-2011, 04:54 PM
Greg Arehart's Avatar
I used a sheet of .063 Al screwed to the bulkhead behind the baggage area (just behind the corrugated baggage bulkhead) and then put the battery box and master relay on the back side of that sheet. This ultimately requires that you run a large cable from the battery to forward of the FW, plus a wire for the master switch to the relay. This takes about 15 pounds off the firewall and puts it considerably aft of the CG so will help a nose-heavy condition. It does add a couple pounds extra weight because of the 10-foot heavy copper cable.
There are a couple threads out there that describe similar solutions.
PM me if you want more detailed instructions, but I'm traveling right now and won't likely get back to you until after the weekend.
greg
Greg Arehart
N 7965A
