Old 08-06-2011, 08:48 PM
aarvig's Avatar
aarvig aarvig is offline
Default Loc-tite usage...
Does anyone have any recommendations on the application of loc-tite on jam nuts installed on rod-end bearings in the elevator of an RV-9A?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 08-06-2011, 09:04 PM
Walt's Avatar
Walt Walt is offline
Certainly won't hurt (and I often find these nuts loose), just be sure not to get any in the bearing.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-08-2011, 05:37 PM
dedgemon's Avatar
dedgemon dedgemon is offline
Default absolutely
I use the blue on all of the control linkages. Bit of peace of mind and easy to take apart later when needed.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 08-08-2011, 06:07 PM
Greg Arehart's Avatar
Good idea! I think I'll do this at my next condition inspection. I sometimes find these nuts backed off as well.
cheers,
greg
Greg Arehart
N 7965A
Old 08-09-2011, 12:39 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
If you use Loctite 220, it is a "wicking grade" and you can apply it to an already torqued nut.
Loctite 220 is blue and a medium strength for #2 to 1/2 inch fasteners and should be at your local auto parts store or Grainger and RSHughes.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
