Any recommendations on whether or not to lube the rudder cables, more for protection against corrosion than anything else? If so, what lubricant is recommended?
Rich and Cindy Macrafic
Rochester, MN
Flying
The cables are stainless so I really don't think they need lubrication or protection. Mine are 11 years old and show no signs of wear. The plastic bushings and tubes I rotate during anual as the cable is a great saw.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Hey Tanya, you're going to be back there later this month for inspection. Don't forget to rotate the snap bushings . It will only be 120deg. in the tailcone.
Scott Card CQ Headset by Card Machine Works CMW E-Lift
