Old 08-06-2011, 08:32 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Comm antenna mount reinforcement plate
Anyone with pictures of their comm antenna mount reinforcement plate? I am mounting a Comant 122 on each side of the bottom center fuse in the outboard bays and slightly aft of the aileron push tube hole in the side of the fuse. It is a bit flimsy. I figure someone has already choosen this location with success. Thanks a bunch!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 08-06-2011, 09:31 AM
pkill's Avatar
pkill pkill is offline
Hi Mike,
Did the same thing here…. Added a bend on the outboard edge along the longitudinal and a angle attached to the inboard rib for added stiffness…. mounted them far enough aft so we could still swing a hammer to drive the wing bolts in without interfering with the 122 mounts….
pk
Old 08-06-2011, 09:34 AM
pkill's Avatar
photo at this link....
http://tinypic.com/r/20kb33d/7
Old 08-06-2011, 02:59 PM
RVRC's Avatar
RVRC RVRC is offline
Default Go look in my hangar.
I just mounted one same place and have another doubler made on she shelf above my workbench. We just left CUB a while ago. If you can't find the key to my hangar, give me a call and i will meet you out there.
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
Old 08-07-2011, 09:03 PM
mikehoover's Avatar
Hey Robert,
Can't believe I missed you and Gail yesterday - I was in my hangar working amongst all those degrees - all 100 of them! Great to see you both today!
Thanks pkill for the photo and info!
Here is what I ended up with:
http://www.aclog.com/rv-9a/images/Fi...8_IMG_0721.jpg
The antennas are much more ridgid.
Mike
Mike Hoover
Columbia, SC
www.eaa242.org/
