I had the same problem. Because of the fore-aft play of the hinges, I could move the trailing edge up and down easily. The solution was simple. Before riveting the hinge onto the tip, pick a spot on the hinge close to the middle. Take a ball peen hammer and peen a spot on the hinge flange to stretch the hinge a few thousandths. Be careful, it only takes a few whacks with the peen to stretch the hinge longer. I just opened my bench vice up with the hinge eye down and used that as an anvil.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
