Old 07-31-2011, 01:43 PM
John Courte John Courte is offline
Default 3-conductor shielded OK substitute for 2-conductor shielded?
I'm wiring my avionics stack, and I have run out of 2-conductor shielded 24ga wire.
I have a ton of 3-conductor 24-ga shielded wire, and I was wondering if it's acceptable to use the 3-conductor in place of the 2 conductor I need by using only 2 of the 3 wires and clipping the 3rd one off at the insulation.
thanks,
-John
RV-7 N313TD
SOLD 7/2/2020
Old 07-31-2011, 02:02 PM
AltonD's Avatar
AltonD AltonD is offline
Perfect. and added words to meet the minimum post.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-31-2011, 02:09 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
It will work just fine. Whenever I use 3-conductor shielded when I only really need 2, I sometimes just connect the extra wire to ground.
Neal Howard
Airplaneless once again...
Old 07-31-2011, 02:43 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yeah guys, of course it will work....but think of all the excess WEIGHT that he'll be adding to the airplane!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-31-2011, 03:31 PM
Thanks guys!
As for weight, maybe I can ride my bicycle to work a couple of days a week and save it that way...
RV-7 N313TD
SOLD 7/2/2020
Old 07-31-2011, 04:17 PM
Haaaa hhhhhaaaaa. Great answer. You know I was just thinking about this the other day. People get all excited about four nutplates adding extra weight, for example, when, really, it'd be a lot healthier if we just lost a little of our OWN weight to compensate.
Well played, sir.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 07-31-2011, 05:00 PM
scard's Avatar
scard scard is offline
Ha, I just came in from the shop where I was installing 12 nutplates just because I might (long shot) want them there some day.
Scott Card
CMW E-Lift
Old 07-31-2011, 06:12 PM
bpattonsoa bpattonsoa is offline
Seems to me that you would want to connect the extra wire to the shield at the end that the shield is grounded and leave the other end free. Ground loops????
Bruce Patton
Old 07-31-2011, 06:25 PM
az_gila's Avatar
az_gila az_gila is offline
Bruce Patton
Yes, since the extra wire is inside the shielding just let it float.
Grounding will have no effect unless you ground at both ends and make a loop - which is usually not good as Bruce says...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-31-2011, 10:08 PM
flion's Avatar
flion flion is offline
In fact, I'd be sure to heat shrink over the clipped wires so they don't inadvertently contact something.
EAA Technical Counselor #5357
